Question about GE Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is providing too much power and over cooking .
  • GE Master
  • 9,098 Answers
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
Jan 13, 2018 | Microwave Ovens
Microware trun table does trun
Try to turn the turntable coupling under the glass tray by hand it should be pretty hard. If not, you may have a broken coupling. Those are plastic with a D shaped hole in them. If it has cracked, or broken, the motor cannot turn it. So either a bad coupling or a bad motor.
Oct 09, 2017 | Microwave Ovens
I have a G.E. space saver micro wave that quit cooking suddenly everything else seems fine Model DVM 1850
Sounds like the magnetron has gone bad. Check around the internet for a replacement ($40 bucks or so), there are couple of blogs on how to replace... need some patience since it takes a couple of hours. The diode might be bad and should go ahead and change it while you are in there. Be sure to discharge the capacitor...
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Need to replace handle on micro wave can not
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
My microwave is not heating, and the table is not turning.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Oct 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Plastic hold glass in door has cracked and broken
find out how much new door is compared with new m/wave.
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
GE micro wave Spacemaker
The turntable is either plastic gear driven or uses a belt. either way, it's usually all non metallic due to the microwaves. you'll need to see if the motor that drives these are turning by removing the case. this can be EXTREMELY dangerous as the radiation from the cylstron tube. if it's a simple as a belt, the part can be replaced. good place to go is
Be sure and rate me for this solution
Feb 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
128 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
