Question about Kenmore 15208 Mechanical Sewing Machine
Machine moves normally but does not sew
I have this machine for at least 15 years, I'm an experienced sewer. Now, the machine is threaded normally, bobbin thread is caught and in place, fabric is in place, machine sounds and moves normally, but no stitiches - what to do?
Okay, I know that you are an experienced sewer and have probably already checked, this but I had the same exact problem today and cleaning the shuttle race fixed it.
Posted on Aug 18, 2008
Everytime I go to sew the thread always knots up
The bobbin thread must go through the bobbin tension guide before it can be picked up to the bed of the machine by the needle thread. There must be a mistake in threading the upper thread or the bobbin thread, or both. There are lots of manuals for sewing machines online and plenty of sewers who can help you in the area where you live. It's not a big problem just go to the nearest sewing store in your area and you'll get lots of help.
Oct 12, 2014 | Sewing Machines
The upper thread in the backside of the cloth comes bundle and after few stiches the wheel stops with the thread jam in the hook of bobbin. i kept thread tension at 3, 4 and 5 ,cleaned the bobbin and...
Wow, what a challenge. There are a lot of reviews/complaints about how temperamental this model is- sewers either love it or hate it and have the same problems you describe. Since I am an experienced sewer and have lots of vintage black Singer models, ( I got rid of the newer models), I wouldn't mess with it any further...If you can, take it to a Singer authorized repair person....they can sort it out for you. Sounds like you've done everything you could so far. Good Luck.
Jul 23, 2011 | Singer 8280 Mechanical Sewing Machine
I have cleaned the machine. I have tried both solitions in my Jaome machine and still loops are forming on the botom. i have even moved the little screw on the bobbin- tested the thread and changed the...
If the loops are forming on the bottom it is the TOP thread tension you need to check. Make sure it isn't too loose. Also is the needle the right type and size for the fabric? Check the stitch out on plain cotton fabric if a tension adjustment doesn't fix it.
The TOP thread effects the UNDERSIDE of the stitch and the BOBBIN thread effects the TOPSIDE of the stitch :)
Jun 05, 2011 | Janome Sew Precise Mechanical Sewing...
Bobbin thread bunching, fabric not advancing
Check your manual to find out how make sure that the feed dogs are up. Those are the "teeth" on the bottom that move the fabric along. If you're not sure or can't find the manual then posting the question with machine's model number might help.
If the fabric won't advance because the bobbin thread is jamming: Check to be sure that your tension is set correctly and that your machine is threaded correctly - even experienced sewers can occasionally miss a spot like forgetting the change the loop after rewinding a bobbin. Also make sure the the thread in your bobbin is the same brand and type as the spool that is threaded. An imbalance in the types of threads can throw off the tension.
Jan 12, 2011 | Kenmore Sewing Machines
The thread jams in the bobbin well
Make sure that you are using the correct bobbins and you have put the bobbin the right way around, make sure that you have threaded the machine correctly, and the needle is around the right way, these are a few things you can check.These are just a few simple things that a lot of inexerience sewers could check before going to a technician.
Jan 14, 2009 | Kenmore 15616
Hard to turn flywheel?
just to let you know Euro pro is a off brand and has had many concerns, try oiling the machine in the oil holes provided and also at needle arm, let me know and i will give you more advice
Jan 21, 2008 | Euro-Pro Shark 80 - 7133
Stiches skip
Things to try:
1. New needle.
2. Make sure the needle is put in the correct way (there are fronts and backs to the needles).
3. Make perfectly sure that your bobbin is put into the bobbin case correctly (the thread going clock or counter-clock wise as indicated in the directions)
4. Make sure your bobbin thread is wound through the case and out as indicated by the directions
(these points vary DRASTICALLY by model of machine and brand).
5. Holding about 4 or 5 inches of top thread, rotate the flywheel (on the far right of your machine) by hand (don't use the footpedal). The needle should go down, it's thread creates a loop, and the bobbin thread loops through that loop; as you continue to rotate the flywheel, the needle will come back up, bringing its own thread AND the bobbin thread. This is when the machine is ready to sew (when both threads are up).
6. If your machine has been moved around and not very gently, then it is possible that the bobbin case and housing have been jostled out of alignment. If that's the case, then you'll need an experienced sewer to look at it for you - mostly that's a case of minor adjustment.
If you remember that the needle is flying up and down thousands of times in a minute, then having all these elements in perfect alignment makes sense.
Even experienced sewists get stumped with this, especially when working with a new machine.
Dec 30, 2007 | Singer CG754 Mechanical Sewing Machine
Brand new-has not sewn first stitch
Phone the store you bought it from and arrange to return it for instruction on use, or a refund.....if it is brand new, it is under warantee and you are entitled to a product that does what it should......if it is you who has done something wrong in the threading, a quick lesson with someone should solve the issue. Either way, call them and get it sorted out.
Dec 01, 2007 | White Sewing Speedylock 1600 Mechanical...
Kenmore 15208 Mechanical Sewing Machine Logo
101 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
