Question about HP LaserJet 3050 All-In-One Printer
Scan tI purchased the all in one fax, copier printer and scanner, but no instructions came for scanning set up.
  • HP Master
  • 2,794 Answers
Kan inte instalera skrivaren Lexmark E232 till min dator, Fujitsu Simens. Finner inget installationsprogram att ladda ner.
Du f?r tillg?ngsupport.lexmark.com webbplats f?r att ladda ner och installeraskrivardrivrutiner. Kontrollera att du valt r?tt filter f?r dittoperativsystem, n?r du installerar drivrutinen, dubbelkolla anslutningen mellandatorn och skrivaren. P? skrivare och fax kontrollera att r?tt skrivare ?r valdsom r?tt standardskrivare. F?r ytterligare hj?lp,kontakta Lexmarks tekniska support.
Jan 20, 2011 | Lexmark E232 Laser Printer
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
How to reset tóner counter?
Try an nv ram. turn off, hold down the right arrow and the cancel button and turn the printer back on, hold until permanent storage init is displayed.
Al
Oct 20, 2009 | HP Laserjet M2727nf Multifunction Printer
Printer scans black images
okay, go to control panel=printers and faxes then right click on the printer you using and scroll down to proprties and then check your settings. if this does not work then check if your cartridges are inserted correctly if the problem is not solved then take your printer to the place of purchase...there might be ink clogged and they can assist you on this.
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can't scan on the HP OfficejetJ4580
Uninstall everything that has to do with your old HP printer, drivers, photo processing, etc. Reinstall software with J4580 printer. That should open HP Digital Imaging Monitor where you can set scanning options. Plug printer into the back opf your computer. Plug power supply directly into the wall socket.
Nov 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP LaserJet 3050 All-In-One Printer Logo
52 people viewed this question
Ben Johnson
