Question about Panasonic Lumix DMC-FX3 Digital Camera
Shutter The other night when I was taking pictures, my shutter seemed to get stuck half way through opening everytime I shifted into picture mode, and I'd push it open with my finger and it was fine, but now, I cannot get them to open at all in any mode. I can't use my camera at all!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey laura0157,
I would first try resetting the camera to the default settings, and directions on how to do this are on page 22 of your user manual. I have included a link to a PDF download of your camera manual in case you need it. If this doesn't resolve your issue I would have the camera looked at by an authorized service technician. I hope this helps!
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FX3K
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 08, 2008
My samsung s760 has ahorizontal lines when you shout in a day time but if you shout it it evening the picture is ok.eventhough i put off the flash in day time it is the same result.what can i do?please...
Mary,First check to ensure that your camera is in automatic mode, and not in one of its manual modes. For example, shooting in a night scene mode in daylight could cause these symptoms. But if you are in auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 11, 2011 | Samsung S760 Digital Camera
Hi! We currently have a problem with our camera (casio EX-S770). every picture i take outdoors are white, while indoors, the pictures horizontally striped, what should we do? and is there a CASIO company...
One of two likely problems. First possible problem is that you're not in auto mode, but one of the camera's manual modes (such as for night shots). First verify that you are indeed in automatic mode. Second possible problem may be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 18, 2011 | Cameras
My s2is powershot camera works fine but it seems the lens will not open there is nothing in the view finder, it takes picture but it is black
Dec 18, 2010 | Canon PowerShot S2 IS Digital Camera
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Camera opens normally, only takes black pictures
May 09, 2010 | Canon PowerShot A530 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen and viewfinder only shows black....no picture
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 02, 2009 | Canon PowerShot S5 IS Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Panasonic Lumix  DMC-FX3 Digital Camera Logo
127 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
