Question about Microsoft Xbox 360 Console
2 left side red 1/2 ring ligts
When playing our xbox 1/2 ring of red and the screen goes black, Then you have to wait until it fixes itself.
    Sniper:
  • 55 Answers
These two lights are actually an indication of overheating. Typically this happens if the heat synch is not making good contact with the cpu or gpu, or the cooling fan is not working properly.
If the fan gets really loud just before it overheats and turns off then it is likely a heat synch issue
You can try searching for the xclamp replacement fix (I won't leave my own tutorial here as there are a plethera of them out there, just use a search engine to find them)
If the fans do not make noise - it may be that they are not working properly, you may want to replace it with another cooling fan. Talismoon fans are widely available and very quiet.
Try cleaning the console - dust and debris trapped inside the console traps heat as well.
Other than that if the console is usuable for more than a few minutes and it overheats after an hour or more, then you can try removing the heatshield (metal piece located under the top plastic cover) and or replacing the cooling fan with a more effecient fan. Please note that removing the heatshield is not recommended as it protects the top of the console from the extreme heat built up by the console, but removing it does allow for a much more significant amount of air flow.
Try and keep the console off the ground - along with the power supply
Play it horizontally instead of vertically and keep it away from carpets which trap heat and other sources of heat.
As always contact microsoft for warranty info prior to opening the console or letting someone else fix it for you.
Hope that helps.
Posted on Jul 04, 2008
How do u fix the three red flashin lights on the 360
(do it on your own risk} it has 70%chances to problem solved.
it is just a trick dont blame me if anything happend
try to unplug all wires and replug ***
1. run xbox for 1/2 hr
2. wrap (cover) ur xbox in towels , wait until it get switch off by itself(due to over heat)
3. unplug the xbox , shake it in all direction for 10-15 sec , hit slowly on both sides of xbox
4. now switch it on , if u find any red ring then, cool the xbox using (a/c, fridge ) not for too long.
i think the pro will solved
Mar 05, 2010 | Microsoft Xbox 360 Console
Whenever I turn it on, it has a red light on the bottom right of the console. The screen says E-74 Error. I was reading how to fix it, some suggested its the A/V Cable. I tried to blow any dust off, and...
simple fix my friend mine broke today was going to play a game and message came up. simply take about 2 towels wrap your xbox up with no games or hard drive in but keep the power supply and av cable in. let it sit for about 20 mins until the bottom red light goes away and 2 red lights appear on the left side. then unwrap it and wait 10 mins turn on it should work hope this helps!
Nov 26, 2009 | Microsoft Xbox 360 Console
Two red lights on left side of power button, vibrating controller
Hmm maybe your Cables are not perfect plugged in or keep your xbox off for 24 hours if it doesnt work let microsoft fix it if you dont got a waranty anymore buy a new one.
Sep 12, 2009 | Microsoft Xbox 360 Console
Red light on first xbox
Cracked solder points try turning it on with the fan unpluged and wait untill you get the 2 red rings lights 1 and 3 then wait until the xbox shuts off then wait a couple of min. then reconnect the fan and turn it on to see what happends.
May 23, 2009 | Microsoft Xbox 360 Console
Startup screen goes black.
I would try having the firmware reloaded or updated. Sounds like a problem there. Try going to xbox.com and downloading the update for playing older xbox games. This also updates the firmware.
Joe
May 20, 2009 | Microsoft Xbox 360 Console
Two red quadrants light up on the left and screen goes blank.
there are two posibilitys to your problem it could be either there is something unpluged in your 360 or your could have a virus you should take your 360 apart and check it if it is still under warrenty through microsoft you should send it in to them and let them fix it but if it is out of warrenty then you should get the tools at your nerest radio shack and take it apart and check it out and let me know what happens
Feb 28, 2009 | Microsoft Xbox 360 Console
Black screen with white bots on screen.(Xbox 360)
It's probably just the red ring, you can fix that with almost ALL 3 red ring fixes.
Cause there both CAUSED by the motherboard shifting.
Google PENNY TRICK, it doenst always work UNTIL the box is completely screwed back in.
Xclamp trick. Google taht too, it costs money for the kit, but it works like everytime and there are TONS of tutorials online for it.
Jan 10, 2009 | Microsoft Xbox 360 Console
Sound, but no Picture
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio , video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Dec 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
904 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
