Question about Insignia 37" LCD Flat-Panel HDTV
Closed Captions For some reson, I cannot get the closed captions off of my HD programs...I've tried using the remote but it always says "No cc informationn." Any suggestions?
  • sallykus Jul 23, 2008
    Yes! The cable box adjustment worked! Thanks!
    Sergeant:
  • 280 Answers
Form your remote on normal signal, go to menu and video options. find closed caption, select CC and tun off text. That should keep it off at all times
Posted on Jul 23, 2008
  • coyotedave Jul 23, 2008
    If you are using a Sat box or a cable box. You may have to do the same to them
Panasonic viera cc
Try identifying which caption is from the TV and which is from the cable box by turning the TV Closed Caption on and off while you have to sets of captioning. This will show you which closed caption never turns off.
Aug 08, 2013 | Televison & Video
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Closed caption
Have you verified that the programs you're viewing have closed-captioning service? Some programs and stations do not support CC on programs and commercials. The closed captions are accessed on the HD52W56 by pressing Menu > Preferences > Closed Captions on the remote control and following the onscreen instructions. Select CC1(the first choice for caption); this is the format most stations send in. Good luck!
Jan 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
Closed caption on dvds
Your TV will need to have (CC) capability. To view Closed Captioning (CC) information from a DVD using the CC function of the television, turn off the Progressive Scan function of the DVD player. If the DVD player doesn't have progressive scan then follow the instructions from your TV manual to setup closed captioning.
Jul 14, 2007 | Sony DVP-NS575P DVD Player
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Insignia 37" LCD Flat-Panel HDTV Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
