Please could you help me i have a DVDR 3380 and i'm trying to record a prog but after its recorded it the dvd just says BLANK on the screen, ive try a few disc but the same thing just happens!! please help me!!
Thanks Tam
I also have the same problem with my Philips DVDR 3380. After recording a prog and then playing it back the dvd just says BLANK on the screen, and it even says UNKNOWN on the display I'm using the right discs 'Philips DVD+RW' discs and its so annoying!!!!! HELP!!!!!!! I also have the same problem with my Philips DVDR 3380.After recording a prog and then playing it back the dvd just says BLANK on the screen, and it even says UNKNOWN on the display I'm using the right discs 'Philips DVD+RW' discs and its so annoying!!!!! HELP!!!!!!!
You can't post conmments that contain an email address.
Check your scart leads first if they ok check u recording on the right setting if u have freeview etc try setting it to record on ext2 it worked for me.good luck
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
- RecordNow! can record only to the same disc type it records from. For example, you can record a DVD only to a DVD+R or DVD+RW disc, and you can record a CD only to a CD-R or a CD-RW disc. you were using DVD-R, so it won't work.
Unless the tv and dvdr are paired I.E. both the same make and compatible models, then you will have problems. try setting the timer on the dvdr for a programme but set the channel to av(scart connecter used) and set the timer on the tv to the same. Please note that AV2 on the tv usually sends the programme to the dvdr.
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
HELP!!!!!!!
