When you push the auto scan button on a radio tuner, the tuner will automatically scan through the available frequencies (also known as a "band") and stop on any station that it finds. The radio will then display the frequency or channel of the station and allow you to listen to the broadcast. The process of auto scanning can vary depending on the specific model of radio tuner that you are using, but in general it is a quick and easy way to find all of the available stations in a particular band. Some radio tuners may also allow you to save the stations that you find during the auto scan process, so that you can easily access them in the future without having to rescan.
Connector scan tool and confirm that the light is not working. The scan tool in its normal process goes through a start up process that lights ck engine indicator.
Most auto parts store will do a complementery check when they are not busy.
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
If you select these options on your printer, you must have an application on your computer that will process the results of the scan. You can scan to a file for processing of an application like photoshop. Your email program must be able to handle the file format you scan in. In either case, you will be asked which application will be used to process the file or email attachment.
