Question about Shinco SDP-1850 Portable DVD Player
European map I need a sd card for my sat nav to cover europe
  • 550 Answers
Any SD card can be loaded with the map in a pc with a card reader,
SD cards start under $15.00
the map can be downloaded from the makers web site,
sometimes at a fee,
the site cant be determined because you did not state which GPS
Posted on Jul 04, 2008
How do I convert my sat nav from europe to usa
Some Sat Navs can't convert, If it's bought & set to UK & Ireland maps, then you are stuck. 2nd thing , even if you can use Europe Maps on your Sat Nav, you still will be unable, to load USA maps.
Sat Nav not compatable, You will have to buy a NEW ONE.
Mar 07, 2015 | Garmin nuvi 255W GPS Receiver
Hi Experts I have a ford focus with a Blaupunkt Sat Nav, similar to the second one on this link with the standard type SD card and two select controls:-...
if the unit was in uses while the sd was pulled out it could of damaged the files on the sd card. you can check the files on a pc but not run the files. the sd card has all the info for the sat nav system if it can not find or use a file it will not let you change the file. you need to do a scan on the sd card. its like a pc if you not eject the sd before removing it damages the filing system.also the web page is not accessible in my area. i would need the model number of the unit. there are software patches and map updates for all nav systems you may need to update the sd mapping software. from the manufactures web site
Jun 29, 2017 | GPS
When updating a sat nav do you firstly update software first or map update
When you go to update your maps the website will check your software and if it needs updating it will update it first. If you need advice on how to update your Garmn satnav go to http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Sep 21, 2010 | Garmin n?vi 1340 GPS for Europe 43" screen...
I would like to know if I can donload maps for europe and where i can get them
Go to www.garmin.com If you haven't registered your sat nav you'll have to do that first and connect the satnav to your computer. You'll have to buy the map I'm afraid as there are no free maps for garmin satnavs. The full map of Europe is around 4 Gigabytes and will not all fit on your satnav even if you replace your home map so I would suggest just buying a map of the area of europe you want e.g. western europe and install it on an SD card. You'll have to install some of the map onto the satnav before you can install the rest of it onto the SD card i.e. select one country, so be sure you have some free space on the satnav. It takes about 3 hours to install not to mention the time to download so maybe it'd be easier to just buy a satnav with a map of europe on it.
Jul 22, 2010 | Garmin nuvi 250W GPS Receiver
Where can i get an sd card with europe maps on for my binatone a350 sat nav?
USA: BESTBUY
EUROPE: TECHNOPOLIS, TECHNOMARKET
or the manufacturer stor
Jun 10, 2010 | GPS
I downloaded a new version of the Garmin Europe maps (2011.10 from 2010.10) but it is too large a document for my sat nav a nuvi 255. I have now only got central and eastern europe, which I want , but I...
Copy the new maps onto the SD card be sure that the card has enough space on it. ( you might need a SD Card reader ) copy the old maps onto your PC before deleting the SD card, copy all the data into the root folder of your sat nav. hope this helps
Apr 27, 2010 | Garmin Nuvi 255 GPS Receiver
I have just bought an x type jaguar. The sat nav system only recognises the european network and no postcodes in england. Any ideas please??
Ensure the map data dvd that you have for the car covers the uk. it might only cover mainland europe is should state GB on the packaging or on the disk itself.
alteratively in the set up the previous owner may have removed uk maping or uk post codes from the system and they may needed to be reloaded.
if your system an navteq one prior to 2003? it is known that the mapping from that period did not support uk post codes i assume buying a new mapping software will resolve this issue. I would recommend checking with jaguar in case any system software upgrade is also needed to read later mapping data versions.
Nov 12, 2009 | 2005 Jaguar X-Type
I need a Myguide gps map card,
Ebuyer does an sd card with uk and western europe for £20
Aug 11, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Shinco SDP-1850 Portable DVD Player Logo
107 people viewed this question
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
