How to put right my dvd rw,it isnt recognized by any of my 2 computers,cant config back as i deleted config,to free up memory,it was working ok yesterday,now it just says(E:)DVD RAM Drive,any suggestions welcome. thank you in advance
  • David Smith May 11, 2010
    What type of dvd rw do you have? have you tried going to manufacter and downloading the drivers?
Grap a pin and the moment the system starts keep hitting the dell or the f2 key once we reach the bios , grab a pin about 5" long and insert in the emergency hole. you would require a small pin/lever. once yu insert the pin toyld dhould fel a small gere/ this should take mat work. !!thanks budy,..
Posted on Jul 17, 2008
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Mydvd drives not work
1. Go to start, run, type regedit, click ok.
2. Back up your registry before making any changes:
Click on file, export, type reg backup as file name and save it wherever you want. (If something goes wrong after doing the next steps, just open this backup and it will restore everything back).
3. Click on the plus sign next to HKEY_LOCAL_MACHINE
4. Click on the plus sign next to SYSTEM
5. Click on the plus sign next to CurrentControlSet
6. Click on the plus sign next to Control
7. Click on the plus sign next to Class
8. Click on the plus sign next to {4D36E965-E325-11CE-BFG1-08002BE10318}
9. On the right pane, click to highlight Upperfilters
10. Right click on Upperfilters
11. Click on Delete
12. Click on OK
13. On the right pane, click to highlight Lowerfilters
14. Right click on Lowerfilters
15. Click on Delete
16. Click on OK
17. Close the Registry Editor
18. Reboot the computer
Apr 04, 2011 | Samsung SH-S222A/BSBF DVDRW Drive - DVD+R...
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DELL COMPUTER W/ Home XP w/sp3 - Recognizes both DVD and CD/RW but NEITHER will recognize or read. ALL UPDATED DRIVERS Loaded, Bios is Latest available. ATAPl iHAP222 DVD/CD and SONY CD-RW CRX217E ...
Hold it! Not just yet. Let's try doing a few steps here.
This is a bit complicated so we have to be very careful in doing so. The main goal that we have is to Delete the Upper and Lower Filters on your registry, and that's what makes it complicated.
To start with
>Click on START
>Type REGEDIT on the search bar on START Menu
>Expand HKEY_LOCAL_MACHINE
>Expand SYSTEM
>Expand CurrentControlSet
>Expand Control
>Expand Class
>Click {4D36E965-E325-11CE-BFC1-08002BE10318}
>Look for the Upper Filters / right click on it / click on Delete
>Look for the Lower Filters / right click on it / click on Delete
>Try you CD / DVD ROM
I hope it helped you out. Rating my assistance will greatly be appreciated. Should you have any followup questions feel free to post it here and I always get back to my resolutions. Thank you for choosing FixYa! Have a good one.
Jan 24, 2011 | Lite On Liteon DVD-IHAP222-06 Black 22X...
How to delete content on cd-r from windows vista 64-bit
Hi and thank you for using fixya.
First of all you can only delete content when you have a CD-RW unit on your pc. Also the CD that you would like to delete has to be CD-RW as well. If all of the above apply follow this instructions:
1- you will put the CD in your computer. 2- go to my computer 3- open the D: drive 4- select all content 5- press the delete on your keyboard or right click delete
Hope it works
Good luck
Mar 14, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Desktop DVD fails to recognize "commercial" DVDs
Hello my friend,i can think only 2 things.The first thing is the region code.So right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button and go to DVD/CD-ROM drives,double click to open the tree.Then choose your dvd burner and double click or right click and properties to open the dvd properties.Go to the dvd region code and select the code/country that the dvd supports and click OK.Also you can download a program called region free.The second thing is that your drive supports CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD+R DL, DVD-R DL, DVD-RAM so if the disc is something else then is not supported by your reader/burner.
Feb 08, 2010 | LG GSA-H55N DVD-RAM Burner
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
DVD-RW Not recognized in Dell Inspiron 1525
Turn off your laptop, take the dvd-rw drive out of the laptop and then reseat it back into the slot so it snaps into place. Turn the laptop back on and make sure its recognized in My computer.
If it is reocognized then try to burn again and see what happens. If it still gives you the same message, see if your drive will read regular dvd movies. If it doesn't then that means the laser is going bad and the drive will need to be replaced.
May 18, 2009 | Dell Inspiron 1525 Notebook
DVD/CD Drive Not Recognized
this issue would be resolved with a simple step which i have provided below.
Click Start, click Run, type regedit and then click OK. Registry Editor starts.
In Registry Editor, expand My Computer, and then expand and open
HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane (topic area), right click UpperFilter and delete the entry, also right click Lower Filter and delete the entry.
Close the Registry Editor and Restart the computer.
I am sure that this will work for you.
Please do rate the solution.
All The Best
Sammy
Oct 31, 2008 | HP LightScribe dvd640i (DVD640I)...
Problem with Optical Drive SONY DVD RW AW-Q170A
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
Aug 05, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
