Question about Fuji Cameras
My camera wont charge - Fuji Cameras
    Problem Solver:
  • 14 Answers
1 Is the charger unit OK? Connect a voltmeter to the camera plug to test the voltage. While connected, wiggle the wire at both ends to test if it is broken. If not OK, replace charger unit.
2 Is the battery OK? Test battery voltage with voltmeter. Connect crocodile clip leads to the voltmeter probes and a good charger. (A cut paperclip can be inserted into the center connection of the charger.) Check that meter reading is positive, and then hold meter probes on the battery terminals, making sure polarity is correct! Voltage should drop immediately, and then start to slowly but steadily rise after after a few seconds. No change with a flat battery indicates battery failure. Replace battery.
3. If both charger and battery are good, then problem is with camera. There are no user serviceable parts inside the camera, and as with laptop computers, it will probably be more economical to buy a new product, and take advantage of the always cheaper prices of newer and better models.
Posted on Jul 15, 2008
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
Why my vivitar camera 5118 wont charge
This is because the 5118 is a camera, not a battery charger. It uses disposable alkalines or rechargeable NiMHs, but if you choose to use rechargeables then you much charge them outside the camera using a separate battery charger.
Apr 12, 2013 | Cameras
Coolpix s3000 wont charge from car usb adapter?
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
May 15, 2012 | Nikon Coolpix S3000 Digital Camera
have you check the charger? or is there a power on the outlet? try to charge it from different power source
May 25, 2010 | Kodak EasyShare V1003 Digital Camera
Camera wont turn on
Often these MUST be charged in an external charger FIRST, as the wall unit is NOT able to "Pump them up" from Flat, but are fine for "Trickle charging" the battery. but will NOT charge up from real Flat. Either that or it is a counterfeit, or bad.
Mar 24, 2010 | Kodak EasyShare M853 Digital Camera
My camera wont start, it wont even charge please help
There is a problem in your battery either you need to replace it or you can try to charge it through USB.
If you want to charge your camera through USB follow the instruction:-
1) In the computer turn OFF the hibernate, sleep or stand by Mode. 2) Turn OFF the camera. 3) Connect the your camera to the computer through USB Cable. 4) Wait for your camera battery to charge (Approx. 3 hours)
This may resolve your problem, Else you need to replace your battery
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Kodak EasyShare MD853 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Tape compartment wont close and camera wont charge
You have probably blown the fuse which means sending to a service centre for repairs.
Jun 23, 2007 | Canon MV800i Mini DV Digital Camcorder
Cameras Logo
63 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
