Spooler not running need printer going
I have a Lexmark 1200 with windows XP. I tried to install it myself, but everything that I did nothing works. The words kept coming up spooler not running.
Can you help me?
Need spooler to be running so that my printer can run and I need it for school. Please Help!
Hope this helps. 1. Go to Start - Run and type in " services.msc" ( without the quotes). 2. Enter 3. Scroll down to "Print Spooler" service and double click to open it. 4. Make sure the "Startup Type" is set to "Automatic" then select "Start". 5. Check the Dependencies and make sure RPC service is also running. 6. Try installing your printer again. Good luck!!
Posted on Jul 12, 2008
Cannot get my lexmarkx7350 to work on my computer
In this case you need to follow 2 steps:
1: In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Once this is done if you refresh the Devices and Printers Page you would find the exclamation mark gone from the Printer icon now follow the below steps to install the Printer again:
Now go ahead and download the software from the following Link:
http://support.lexmark.com/index?page=productSelection&channel=supportAndDownloads&locale=EN&userlocale=EN_US
Just go to this Link and select ur Product & the operating System.
Download the drivers from here and install the Printer.....
Good Luck!!!!
Apr 04, 2013 | Lexmark X7350 All-In-One Printer
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
When I press print I get the following message: "The Lexmark 2600 series is currently busy. Your print request will begin as soon as current processing is complete". Nothing prints. The...
There could be some print jobs stuck in the print queue. Try to clear the print queue first before sending a new print job. Follow these steps: - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Apr 25, 2011 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X1180 won`t install on new vista laptop
Okay this is a easy problem, the printer spooler service is turned off, just turn it on, and try to install it again, should work if not let me know.
press start and then run
OR
hold down windows key and press r
in run menu type in: services.msc
and press ok or enter
in services, you need to find printer spooler or spooler, right click on it and select properties.
make sure start up type is automatic, then press on start. Apply ok, close window , make sure the service status is running, press F5 to refresh the page.
try installing it now.
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Pentium4 computer
To start print spooler service, go to start > run > services.msc then press enter. scroll down the list to find print spooler, then right-click then click on start. You need to have it automatically start in the future, so you have to right-click > properties > startup type > change to automatic. Then try reinstalling your printer if necessary.
Sep 06, 2008 | Microsoft Windows XP Professional With...
Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Aug 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Lexmark z600 printer.
since you removed everything, take it one step farther. Try using SYSTEM RESTORE (assuming you have WIN ME or later). This will restore the register for Windows OS. Select a restore date from the list to when you thought the system worked fine-go back to the earliest date if necessary.
Sep 09, 2007 | Lexmark Z600 InkJet Printer
Purchased lexmark 1200 All in One
uninstall the os.formatt the c drive. install the os.then install the printer.it will work
Aug 29, 2007 | Office Equipment & Supplies
54 people viewed this question
k24674
jasbo
jasbo
