Will not print any documents - Computers & Internet
Have you just formatted your hardisk drive?if you have, then when your pc is powered on, click control panel,click printer and faxes and follow the instructions.If after this the printer doesnt print, then check the cable connecting the printer to the system, it may not be connected properly.if there are still any more problems get back to me.cheers.
Posted on Jul 22, 2008
Hi there click start then goto run and type services.msc, on that list look for pint pooler and restart the services......BUT if you get an error msg then go to lexbc server click the dependencies tab and change the failure to restart the service...also go to control panel ...click prin ters and hardwares and a small window might come up so the docx in the q needs to be selected and deleated 1 by 1! please let me know what happens. just keep posting your details instead "will not print any documents" is not enough!!!!
Posted on Jul 17, 2008
First of i need to know what type of computer you aare using then i can help you but you have to check on the process jobs you have in the printing que then delete some of them that might have hang the printer and thus fail to communicate properly with the computer system that is desktop.
get back to me as soon as this helps so we can get another way out kamu2cyprian@yahoo.com
tell me the type of printer you are using
cheers
Posted on Jul 12, 2008
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Will not print adobe documents, prints other documents, please advise
This is assuming you mean Adobe Acrobat:
I have worked in a University and now work in a large state agency and have found that this can occur when people accidentally print to document instead of to a printer. I know it sounds silly, but please give it a go:
  • Try using the print icon print.jpg on the Acrobat tool bar (rather than your browser's print function). On the print dialog box that appears, make sure that the option to "Print to file" is unchecked.
  • If print icon is grayed out, it may mean that the document's security prevents printing.
If this does not work, please give me some additional information (such as which product/version you are using and what kind of document you are trying to print) and I will try my best to assist.
Hope this helps.
Jan 30, 2010 | Computers & Internet
Trouble printing a microsoft word document on
I have HP 3180 All in One Printer...When I try to print from Microsoft Word...I get a statement that says document is "spooling" ready to print but nothing happens. How can I avoid this step and just go to print.
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
