Question about Maytag Atlantis MAV6451 Top Load Washer
Will not spin Maytag PAV2300AWW top loader
My machine has stopped spinning. All other functions still work how can I fix it.
  • Anonymous Aug 15, 2008
    machine spining ; but tub is not spining at all!
Have a matag washer model# LAT9635AAE that had filled up with water and was starting to wash and the lid was opened to put some more clothes in and then the washer would not do anything on any setting.Could it be the timer switch or something else?
Posted on Jul 08, 2011
How do you fix the door switch
Posted on Aug 10, 2008
  • 95 Answers
Check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Posted on Jul 11, 2008
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
Mar 15, 2009 | Maytag PAV2300 Top Load Washer
Pav2300aww
Replace belt, clean large pulley first with household cleaner-409 or greased lightning (pulley is made of plastic).
Mar 11, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
How do you know if your belt is not functioning properly? During the wash and spin cycles the machine makes an outrageous noise. The washing machine is 7 years old, a Maytag Performa, Top Loader, Model #...
  • tilt the machine over and look at the bottom. the belt is there.
  • it will feel loose but that is normal. it is spring tensioned.
  • the noise is probably coming from the water pump, when they are bad they make a loud noise.
  •  turn the pulley around a couple times to see where the noise is coming from.
Jun 28, 2008 | Washing Machines
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
