Question about Sony Car Audio & Video
Sony ipod my ipod is reading disc mode and a tick that says ok to disconnect, but it does not respond to any of the controls
I want a buy sony ipod and please tell me? which is fluency voice is ipod and about this ipod rate?
Posted on Mar 05, 2009
Sony disc player just hissing not plalying
Hello, i just found one of these decks yesterday with the same problem. The deck loads a disc correctly, but cannot read the TOC (doesnt display the title or track number)
The hissing sound is actually the sound of the laser lens vibrating in a unfocussed manner
The solution: 1.Use a minidisc lens cleaner if available.2.If not, eject the minidisc and open the deck. Take a good look at the laser lens. Is it dusty or seems hazed over (cigarette fumes)? (Mine was)
If yes, clean the laser lens directly with a cotton swab to which you add a drop of isopropylene (100% alcohol) or (2nd best choice) window cleaner.
Take care to not bend of break the recording head (the white and copper arm just above the lens)
use a dry cotton swab to pick up any remaning humidity on the lens.
3. Try again to read a disc. any success? No? try, if available, a pre-recorded disc
any sucess then? Chances are it might work with a pre-recorded disc because of the better reflectivity of these discs.
No luck yet? Doest it read some discs, others not? well, it's time to re-adjust the deck. The service manual is available here: http://www.minidisc.org/manuals/sony/service/sony_MDS-JE520_service_manual.pdf for free. BTW the site www.Minidisc.org is an exellent source of all information available about minidisc.
First let the deck tell you what the problem is! Page 2 explains how to enter the self-diagnosis mode. Enter the Error DP (display) mode. Look at the error history. Most probably you will find the code E06 (as i did) which means Focus error.
The service manual explains how to enter Adjust mode.
Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Do C(ontinous)-play checking: 5-6-5 MO error rate check (Page 38)
Perform focus bias adjust (page 41) (5-12) This is a manual adjustment Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Keep in mind that you have to adust the setting "A" with the AMS button to obtain C1=220, and "B" turning the AMS button downwards (anti-clockwise) to obtain C1=220 the deck calculates automaticaly the adjustment "C".
Perform autogain control level output adjustment for MO discs
(page 42) (5-15-2)
If this doesn't work, reset the deck to initial settings / Initial setting of adustment settings (page 39).
Perform focus bias adjust (page 41) again (the deck displays the adress and C-1 and ADER errors)
Check if the adjustment is ok with C-play checking 5-6-5
(page 42) again (5-15-2)
MO-disc= recordable MD
Hopefully you can re-adjust your deck. You don't need any extra tools for this, the deck displays the error rate. In C-play mode, a pre-recorded disc shows nearly always 0 C-1 errors, a recorded disc should not show more than 50 C-1 errors and no ADER errrors.
Of course this is at your own risk. I can only say that i needed about 1 hour to find the setting which worked with different recorded discs.
There is also the Continuous recording mode to check that the error rater during recording stay within tolerance. If you use this mode bear in mind that the disc will be (partially) erased regardless if fully or partially recorded. In test mode there is no safeguard against accidentaly erasing, so use a new disc or one with a recording you don't care to loose.
Simply unplug the deck to exit the service mode.
Check if you can record after adjusting the focus. Check if you can enter a title to the disc. Is the title there when you eject and reload the disc? If yes, you succeded!
Hope this helps!
P.S. Yes, i once was working for Sony as a repair techncian...
Sep 23, 2011 | Sony MDS-JE520 Mini Disc Player
MDS 503 STUCK IN STANDY MODE?
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
Dec 30, 2009 | Sony MDS-JE520 Mini Disc Player
'disc mode'displayed in window, large tick and o.k to disconnect. machine will not respond.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If for any reason this does not resolve your disc mode/frozen iPod issue please do let me know and remember to rate :)
Mel
May 20, 2009 | Apple iPod nano
I plugged my ipod 3rd generation 20 gb into my mac to delete some songs so I could add new ones...the screen came up in iTunes and it said it was disconnected improperly even though it was still hooked...
I would force the iPod into disc mode before attempting to connect the iPod to restore it. Below is a step by step on forcing an iPod into disc mode just in case you need the information :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Apr 30, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod nano has a message on the screen that reads ''disk mode''
Salut, j'ai quelques problemes avec mon ipod Model A1137,2GB c'est que j'ai oublié le corde
Feb 24, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Gone into disc mode and is stuck
How do I unlock my I pod>
Sep 11, 2008 | Apple iPod nano
My ipod is in disc mode and says ok to diconnect it is disconnected will not go to menu help
I pushed the menu button and the middle reset button at same time for 8 seconds and the ipod reset and full menu options came on.
Apr 03, 2008 | Apple iPod nano
Ipod 20gb trouble
t tells me to plug something into it, but it looks like a charger. i do that and i press the menu and the click wheel and the bettery level stays the same!
Dec 15, 2007 | Apple 20gb Ipod Mp3 Player With Click...
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Car Audio & Video Logo
443 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
