Question about Microsoft Xbox 360 Console
HELP HELLO STUART, I REALLY NEED YOUR HELP, MY XBOX 360 IS HAVING THE 3 RED LIGHT ISSUE, AND REALLY I´M NOT AT TECHNICIAN OR ANYTHING LIKE IT... I DO NOT KNOW ANYTHING ABOUT REPAIR AND I DON´T HAVE WARRANTY EITHER, WILL YOU PLEASE GIVE ME A BEGINNER LESSON DETAILED PLEASE IN ORDER TO KNOW WHAT TO DO. THANKS
    Problem Solver:
  • 5 Answers
Simple need to take your 360 apart right down to nothing! tips on this found on websites all over.your then see 2 chips on the board inside (covered by to big metal heat sinks) they need to be reheated with an air gun about 450 'c.this should solve your problem! sorry couldnt be more detailed! if u dont know wat your doin should really send to a repair company.(can recomend)
Posted on Jul 07, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Need a fix for 3 red lights on xbox360
Can't fix it yourself unfortunately. It is a hardware issue. This company can fix it for you.
http://www.nexicore.com/xbox/index.html
Nov 19, 2009 | Microsoft Xbox 360 Console
My red death three ring light is not working on my xbox 360
3rrod is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death).
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet. Im in the middle of producing one right now that i will make available free of charge for all fixya
members.
www.xboxrepairkit.co.uk
Sep 26, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem: 1. Turn off your Xbox 360 console. 2. Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive 3. Reattach the Hard Drive. 4. Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps: 1. Turn off your Xbox 360 console. 2. Detach the Hard Drive. 3. Connect the console to the Internet through an Ethernet cable.Notes • Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory. • If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed. • You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site: http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
Jul 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 repair in mumbai :- 9819767710/9867635653 ?
HELLO ALL GOOD NEWS FRIST TIME IN INDIA
XBOX 360 3 RED LIGHT ? NO PROBLE CALL ME NOW
WE ARE PROFESSIONAL ALL TYPE OF VIDEO GAMES REPAIRING. NOW WE HAVE NEW SOLUTION FOR XBOX 360 3 RED LIGHT FIX. WE CAN FIX 3 RED LIGHT PROBLEM WITH GUARANTIED.
NOW WE CAN PROMISS U FOR YOUR XBOX 360 VERY EASY NEVER BECOME 3 RED LIGHT PROBLEM. NOW WE HAVE VERY GOOD SOLUTION FOR 3 RED LIGHT.
IF YOU WANT BEST SERVICE AND SPECIALIST REPAIRER FOR YOUR ALL TYPE OF VIDEO GAMES.
PLS FEEL FREE CONTACT US
MAHBOOB ALAM & SERAJ AHMAD
MOB : +919867244969
EMAIL : mahboobidrishi@hotmail.com
Website : http://sonyservice.en.china.cn/
Jan 23, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
Red light
The modem doesn't really have anything to do with the 360, it's a separate issue. If the console is freezing and giving you red lights then that's different altogether, please explain with a little more detail and I'll try to help you further!
Nov 28, 2007 | Microsoft Xbox 360 Console
Xbox 360 not turning on, just red flash
It seems the power supply of your console has gone bad. Kindly have a local cartified technician check your Xbox ASAP.
Apr 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
