Question about Philips Televison & Video
I want to replace the screen on my phillips 55pp9401.i pulled the front lower cover off.removed the 4 screws on the bottom of screen.the bottom is lose ,but i cant see how to do the top of screen
  • Philips Master
  • 8,617 Answers
Usually you just have to slide the frame assembly up to disengage the top clips that secure the top of the screen frame
Posted on Jul 04, 2008
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
I am 99% sure I have a bad fan. TV was turning off (probably overheating). We replaced the lamp (for the fourth time), but the fan continues loudly when the set is turned on. Question-- Can I replace...
Tools/Supplies:
• Phillips screwdriver (magnetic tip)
• 1/4" nut driver
• 1/4" wrench, small adjustable wrench, or stubby Phillips (to access screw in tight spot)
• Canned air with extender tube, a few cans
• Optical-quality microfiber cloth
• Clean, lint-free cloth
• Small brush
Precautions:
• Do not use any cleaner that contains ammonia. A clean lint-free cloth dampened with water was adequate for me.
• To prevent over spray, do not spray any cleaner directly on to any TV part. Spray on to rag only. (I only used a dampened rag to clean plastic and metal surfaces; no electronics or optical surfaces.)
• Use only an optical quality microfiber cloth and/or canned air to clean the light engine lens, the mirror and the inside surfaces of the front screen.
• Exercise caution using canned air. Do not tilt the can and allow any liquid propellant to escape. I had a few full cans available, and swapped to a new can often.
• Keep screws removed from each panel in a different cup. Most are different sizes.
• When disconnecting wiring connectors, note color codes for connector orientation when reconnecting. Most connectors only install in one orientation, but it's not clearly obvious.
• If contacting any circuit boards/wiring connectors, make sure to touch the metal frame first to discharge any static charge.
Disassembly Instructions:
1. Insure TV is powered off and allowed to cool at least 2 hours (overnight if possible).
2. Open and remove the Lamp Unit door on left side of TV. Using a Phillips screwdriver, loosen the 2 screws on the lamp unit and carefully remove the lamp unit.
Clean lamp unit, using microfiber cloth on the lens and set aside for reinstallation.
3. With the lamp unit removed, you can see the light engine's color wheel through the small hole. I covered this hole with tape to prevent any dust from entering during my cleaning.
4. Remove the lower rear cover (2 screws on each end and 9 along the back panel).
5. Remove the cover from the Input/Output jacks by removing the 7 silver screws securing the cover to the Input/Output modules and sliding the cover off the power cord grommet.
6. Remove the front pedestal cover as follows:
Note the blue, red and grey wire harnesses on the right side leading to the front panel controls, AV-3 jacks and PC slots. Loosen and remove these wires from their wire ties.Grasp the pedestal cover at the ends and gently pull outward. It is installed with quick-release pins and should release easily.Gently pull the pedestal cover out, being careful to guide the wiring.Carefully disconnect the 3 wiring connectors, noting the color code for reconnection.In preparation of removing the front screen, 2 hidden screws must be removed. These 2 screws secure the bottom corners of the front screen and are installed from the back.
7. Remove the plastic housing where the lamp unit was removed:
Loosen the wire tie and remove the wires from the top of the plastic housing (these wires go to the lamp door switch).Remove 2 screws securing plastic housing. One on left side and other in base on right side (with limited space available, will need 1/4" wrench or stubby Phillips).Slowly pull housing from TV, until you can reach the connector to the lamp door switch. Note color code and disconnect wiring connector (may be easier to pull some wire through the hole and lift upward to remove connector).The front panel screw can now be seen in a recessed hole. Loosen this screw. (I did not remove the screw completely, to aid in reinstallation. Otherwise, a magnetic Phillips screwdriver may be needed.)8. From the area of the front panel wiring ties the other hidden front panel screw can be seen in a recessed hole. Loosen this screw.
9. Remove 11 of the 12 screws along the back of the TV securing the front screen, leaving one loosely installed at the top.
10. Remove 4 of the 5 screws on the front of the TV, at the bottom of the screen.
11. While holding the screen at the top and bottom, remove the two remaining screws, and gently lift and pull the front screen panel away from the TV.
Store the front screen assembly where the inside surfaces can be cleaned with the microfiber cloth and/or canned air.
12. Reassemble the TV in the reverse order, remembering to remove the tape from the hole covering color wheel, if installed earlier in step 3.
There are 3 fans to clean:
The large Lamp Fan behind the lamp and light engine assemblies is clearly visible.There are two smaller fans mounted next to each other. One fan is mounted between the cable card slot and the light engine and the other fan is mounted just to the right directly on the light engine assembly. It's somewhat inaccessible without removing the light engine, but using an extender tube on your canned air, it is easily cleaned.
The lens of the light engine will have the most dust. Clean with canned air and the microfiber cloth. Use a corner of the cloth to reach beneath the plastic tabs covering the lens.
The mirror may have a few dust particles. Gently wipe with the microfiber cloth and use canned air. Hope this helps,
TechGuy21
Jul 04, 2011 | Toshiba 62HM95 62" HDTV
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
How do I replace speakers on a 1994 xj6 ?
Replacement of Front and Rear Door Speakers
Required Tools:
#2 Phillips Screwdriver (magnetic tip is useful)
9 mm Nut Driver
8” or 10” Flat Tip Screwdriver
Small awl or other sharp pointed instrument
Soldering Iron w/solder or 8 to 10 small wire **** splices
8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
Thread locking compound “Loctite” (optional)
6” wooden dowel of ½” diameter to be used as a drift
Small mallet or hammer
1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
3) Remove the Upper Inner Door Panels as follows:
It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
4) Remove the Lower Inner Door Panels as follows:
a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
5) Remove Door Mounted Speaker as follows:
a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
6) Install New Door Mounted Speaker as follows:
Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
8) Perform Steps 3 through 6 for the other doors and the job is complete.
9) Remove Rear Footwell Mounted Speaker as follows:
This sequence is good for both 4” and 5.25” footwell mounted woofers.
a) Using a small flat screwdriver as a lever, carefully ease off the grill.
b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
c) Ease out the old speaker and release the electrical connector for the speaker wires.
d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
e) Re-connect the speaker wires to the harness by joining the electrical connector.
f) Mount the new speaker and re-attach the necessary sheet metal screws.
g) Press the speaker grill into place.
h) Repeat Steps 9a though 9g for the other footwell speaker.
Mar 10, 2010 | 1994 Jaguar XJ6
How do I take the front off my dryer??
check for two phillips screws along the lower raised edge of dryer front...remove screws and raise front by pulling from bottom edge or sides-pull towards you,it should swing upward from bottom...if no screws take putty knife and push retaining clips in on the right and left between dryer top and front.raise top and youll see either 5/16 or 1/4 inch screws securing the front to cabinet on right and left sides
Mar 06, 2010 | Crosley CDE6000 Electric Dryer
How to replace the rear bumper cover on a Chrysler Pacifica
1. Open liftgate. 2. Remove both taillight assemblies by removing 2 hex-head bolts located in the area revealed when the liftgate is opened. 3. Remove 4 plastic retainers on the very bottom of the bumper cover in the rear. 4. Remove 2 phillips head screws in the wheel well rear lip. 5. Remove 4 pop-up plastic retainers in liftgate area. Use two screw drivers to lift the head and then pull the entire retainer out. 6. Remove a hex-head bolt from each side in the area revealed when the taillight assembly was removed. 7. Bend the bumper cover outward on each side to clear the wheel well lip and remove the bumper. Have a blanket or carpet on the ground to protect the bumper. 8. Remove metal clips from tabs that connect the upper bumper cover to the lower bumper cover. 9. Drill out pop-rivets that connect upper bumper cover to lower bumper cover. 10. Push tabs out of slots to separate the upper and lower bumper covers. 11. Release tab locks on chrome trim pieces and remove from upper bumper cover. 12. Reverse this process to replace the bumper cover.
Feb 16, 2010 | 2006 Chrysler Pacifica
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
How do I remove my KitchenAid Drier cover to tighten baffle screw
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to all the main components.
At bottom of upper front panel remove hinge springs and screw at left and right edges. Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove screw on each side while holding front panel in place. Pull upper front panel toward you and off rotating it out of the way being careful not to stretch or break wiring to switch for door.
Reverse the above process to reassemble unit. Good Luck.
Sep 30, 2009 | KitchenAid Dryers
Televison & Video Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
