Question about Frigidaire ATF6000ES Front Load Washer
Water will not enter washer; times out and will not advance.
  • Doug Morin Aug 03, 2013
    Did you figure this out? I am having the same problem.
Washing machine spins during the wash cycle, but the drum will not spin during the drain and spin cycle.
Posted on Nov 21, 2009
  • 876 Answers
The first thing to check would be you incoming hoses. Pull the machine out, UNPLUG THE WASHER throw down a couple of old towels or have a bucket handy. Unscrew the hoses from the back of your machine and check the little filters to make sure they are clean. If they are, replace them and make sure the water faucets are turned on fully.
While you are there, check your drain hose to make sure there is not a big clog that is stopping the machine from doing anything.
If you can not see a problem there go to the site /support or customer service/enter your washers model # when prompted and you will get al ist of manuals and tech data on your washer. You can download anything that you think might help you. It is all in acrobat format, so if you dont have acrobat reader, you will need to go to and download and install it for free. Good luck to you.
Posted on Aug 13, 2008
How to reset a Frigidaire front load washer Model LTF2940ES3
Empty the machine. Turn off. Close door. Try pushing simultaneously 2 buttons at a time while powering up. This would reset the machine.
Jan 12, 2014 | Washing Machines
Change control board on Frigidaire washer LTF2940ES3
This is typically not a DIY type of job since the entire front, top, panel where the settings are needs to be taken apart to reach the control board and wiring harnesses.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire LTF2940ES3 front load washer. I tried washing a down comforter. It has shut off with the water still in it. I tried shifting the load and have now removed the comforter, but it acts...
There is no reset for this unit. Do you get any lights illuminated on the control panel at all?The lights should flash in a sequence to determine a error code. Here is the complete service manual for your machine. Your model is considered the "good model" in this manual which cover two different models. Look at page 61 of the manual to determine the error code and post it back to me. If you don't get any lights on the machine at all and you know you have power to the unit, then the control unit will need to be replaced. Here is the link to the service manual. I will be waiting on your results.
Jan 03, 2012 | Frigidaire GLTF1670A Front Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire LTF2940ES3 Erro 21
ok take the bottom panel off theres two screws,,almost to each corner,,,always unplug first...ok check your pump its on the left and has two black hose,,clean and,,reverse to put together...onthejob..the top panel with door cant be removed
Jan 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2140ESO front load washer won't start. Not responsive to panel button inputs (Spin Speed, Options). Only reponse is three beeps. When I move the basket back and forth, can hear a little...
Dec 26, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
796 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
