Question about Philips 64P8341 64" Rear Projection Television
Tv prob tv changes channels on its own??
  • Philips Master
  • 8,617 Answers
The small signal board is usually what causes that problem.
Posted on Jul 04, 2008
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
TV stuck on blue video screen
This usually happens when you are on a source that doesn't have a signal such as a channel with no signal or an AV input that is not connected.
You should look for a button that has TV/VCR or TV/VIDEO on it. I've guessing that you've already tried to change the channel but if not try that.
Last ditch effort in that case may be to unplug the TV for a few secouds. Warning- this may wipe out any settings you have entered such as the channel programming (which channels to skip while surfing) but along with that goes the blue screen.
Jan 11, 2009 | RCA Universal Remote Control
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Model LD 200 EMB
This may sound stupid and not help anything but I would change the batteries in the remote first; that's the simplest possibility.
What the set is doing is selecting a function, the first is 'Auto tune' during which the set is looking for usable channels on the 'off air' (antenna) input. I suspect you have cable or satellite meaning that there will not be any signal at the antenna input and the set just looks at each standard channel frequency and then gives up.
The language thing; this is curious but also a sign that it has switched to the menu mode where you also need to be if you want to do a channel search on purpose.
If the remote is not at fault, then it is an internal problem you will not be able to repair on your own.
The circuitry that interprets the received infrared signal from your remote has started producing noise or the output from that after a decoder, has gone noisy and is just choosing functions on its own.
The blue screen is what most sets use as a default when no signal is found at any input.
Unfortunately. Emerson, RCA, Zenith and a few others are US names we once trusted but now have been acquired by Asian manufacturers who are building junk with labor pulled from the fields to assemble high tech gear.
Aug 27, 2008 | Emerson EWL20D6 Television
LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
Sep 30, 2007 | LG 37LP1D 37 in. LCD Television
Philips 64P8341 64" Rear Projection Television Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
