Question about Sanyo DS24425 24" TV
Need remote for 2006 sanyo color flat screen tv
Remote has a # under the name
SANYO
GXBA
7.5" long 2.25" wide numbers on top section vol/ch near middle
  • Jaime Hernandez May 11, 2010
    Could you please provide the model number of your TV to locate a remote control?
  • 2,323 Answers
Great info AlmostBob.
Posted on Jul 05, 2008
  • 550 Answers
Replacement sanyo gxba remotes start at $25 at bestbuy, RCA universal remote controls that include the sanyo codes start at $9.99 at CanadianTire, and must be available at the equivalent stores in your region
good luck
Posted on Jul 04, 2008
Need code for my Sanyo Remote GXBA FOR my Sanyo TV model # DP26746 Please....
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 24, 2015 | Sanyo Televison & Video
How do i program sanyo tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 13, 2014 | Sanyo Televison & Video
How do i program sanyo gxba remote and what codes are used for sanyo tv
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
Trying to access input function on my Sanyo flat panel screen with sony DVD remote
Its 50-50 at best that it will program or work.
Another option is take the bad remote to a repair shop--where I work we fix most of them and usually under 20 dollars.
May 28, 2012 | Sanyo Televison & Video
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
I have a two wide line at the top and bottom of my tv picture. how do i get rid of lt? modle number dp37647-e-mail louisdyersr@yahoo.com
Sounds like you just need to change your display mode, look on the remote for a button that says zoom, also in your display menu with your remote, there also should be a setting that allows you to switch from standard widescreen etc. choose full screed or wide screen mode that should get you back to full screen, please keep me posted I would be glad to Trouble shoot this issue until resolved.
Jun 11, 2011 | Sanyo DP37647 37 in. LCD TV
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Jan 25, 2011 | Televison & Video
The book shows 0154 as the code for my sanyo tv ,it does not work .
Hello
If you are looking for its service menu, there is no code, but some doings is necessary as follows.
Two proceedings are given. One amoung them will surely open your TV to service mode adjustments.
To enter the service menu do the following. Most of the sanyo sets will get positve results with this.
OR
* Unplug the power cable.
OK
Jan 24, 2011 | Sanyo Televison & Video
Sanyo DS24425 24" TV Logo
232 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
