Receiver makes clicking sound when I push power, but does not turn on.
My receiver has been having problems for the last few days. I first noticed when I was listening to the radio and out of the blue, the receiver shut itself off. Then, a few days later when I tried to turn it on it turned itself immediately off. Over and over I pressed the button until finally it received power and came on. Last night when I tried to turn it on it made a clicking sound but their is nothing on the screen that comes up and it does not have any sound. The warranty is expired and I took it apart, but I can't tell what is wrong with it. Was playing records and just stopped and I tried to turn it back on and it just clicks the noly way to stop it is to hold the power button down for 3 seconds
  • 71 Answers
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Posted on Jul 14, 2008
Hello: I would like to know if you could tell me if there is a way to get this receiver to work again. As it does not turn on when powering it up.
It sounds like the power supply has gone out on it, I am having no luck in finding a replacement part for you though, sorry.
May 12, 2016 | Yamaha RX-SL100 Receiver
How to I tell if my receiver is dead?
It sounds like it is dead, check the manual.
Be sure you have mains power to the receiver, it sounds like that failed. A loose plug or blown fuse could cause that type of problem as well. Here are a few links that may help.
Redirect Notice
Redirect Notice
Yamaha RX V373BL Owner Manual
Mar 02, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Audio Receiver only makes one "Clicking" sound when I push the power button
Definitely sounds like a relay... How old is your unit? Sometimes they get stuck and need a good cleaning with DeOxit. Good luck!
Aug 21, 2017 | Yamaha HTR-5940 Receiver
I just picked up a used Onkyo TX-SR502 receiver that has no audio output on any of the channels. I obtained a service manual for it and have tried a few things, but dont know the source of the problem...
I have the same problem, how did you initiate debug mode ?
The receiver worked perfectly until a few days ago, then one day it didn't work when I turned it on but started working after a few minutes. The next day it did the same thing and the folowing day it didn't work at all. Have tried the power reset and also had the top off to see if there's anything really visibly burnt - nothing.
This receiver never got bad treatment, left on overnight a few times but not with sound running out, just powered up. It's a bit enclosed I guess so maybe overheated but I find it hard to believe.
Anyway, can someone advise how to initiate debug mode and also what to do with it.
Oct 04, 2010 | Onkyo TX-SR502 Receiver
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Feb 23, 2010 | Onkyo HTR500 Receiver
The receiver turns on riefly and then makes a
The clicking noise is the protection circuit., sounds like you have a grounded speaker wire, but you say the speakers are not connected so the amp may be toast. Is there any smell of burnt wires? This is ussuallt noticable near the circuit board if something failed!
Jul 07, 2009 | KLH Audio Players & Recorders
Will not start up, no response after three attempts.
HI, theses popping sounds were capacitors exploding among other components as well. this is usually caused by a malfunctioning power board that has allowing way to much current in. the main has been fried in this case.
remove the cover and look for a fuse by the power cord solder(connection) point. if there is no fuse in the section, this will confirm major burn out.
Replace the entire main and power Assembly in this case.
May 22, 2009 | Yamaha RX-V663 Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Jan 20, 2008 | Sony STR-DE845 Receiver
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
514 people viewed this question
