Question about Frigidaire Dryers
I have a Frigidaire Heavy Duty gas dryer. The gas ignites and glows for a couple seconds but then turns off - no heat to the dryer. Through my research I have been advised to replace the gas valve coil. Is this correct? How do I take apart the dryer to reach the coils?
  • 525 Answers
Most current models have a removable front panel that allows easy access to the gas valve/coils. Your user's manual should instruct you on how to remove the front panel from your particular model. Coils are probably the most common failure. Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0003.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
I have a Frigidaire gallery commercial heavy duty dryer model #GLGR331AS1 it just stopped heating turns on and runs but no heat. Could it be the solenoids or the igniter ?
If the igniter glows but it doesn't ignite, most of the time, it's the valve coils, most of the other times, it's the radiant sensor.
If the igniter doesn't glow, check your thermal fuse. If your thermal fuse is good, replace your igniter.
Oct 21, 2014 | Dryers
Kenmore dryer heavy duty plus
Igniter could be burnt out
Feb 25, 2014 | Dryers
Frigidaire Gallery Commercial Heavy Duty GAS DRYER Model GLGR331AS1: gas lights and dryer operates for approximately two minutes. Then the gas goes out and approximately 1 minute later the ignitercomes...
Simple. Your solenoids are overheating because of age. Most American dryers use the same 2 coils:
This video of mine shows how to replace them:
Nov 19, 2011 | Frigidaire Dryers
Dryer won't light. Igniter glows, then turns off,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 25, 2011 | Frigidaire Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Need to get to the heating element, how do you do that?
how do i get to the heating element on my frigidaire heavy duty dryer
Oct 03, 2009 | Frigidaire GLER341A Electric Dryer
No heat to our gas frigidaire dryer
Make sure the gas valve is opening, you'll smell gas. Second, check if the glow bar comes on or, if the thermal couple is lined up to the igniter.
Jun 30, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas dryer stopped heating
Your gas valve solenoids are bad, or else the igniter (glow bar) has failed. Hope this helps!
Dec 31, 2008 | Frigidaire Dryers
Dryers Logo
74 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
