Saeco Royal Professional Espresso Machine Logo
Posted on Jul 04, 2008
Saeco royal coffe machine
How do i clean the water hose or change the filter
Thank you
Jacques
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
809
Points
7
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
2answers
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing FixYa.com
Justin
Coffe mashine is blocked
go to this link below for cleaning instructions and manuals, it may help hopefully. http://www.aabreecoffee.com/clean_maintain.cfm
Keep asking to ventilate,when ventilated,coffee does not come out
Run CLR through a couple of cycles and flush with clean filtered water through a couple cycles. Try to use filtered water to prevent lime and calcium buildup, besides, the coffe will taste better - Godd Luck-Ned-
Saeco Roayal Sup 016
Hi
I am assuming your machine grinds, then clicks twice, then the brew drive starts but you never hear the pump.
If this is so? The there is a lever at the top center of the door on the right. Pull the lever back 1 click, and try again.
2helpful
2answers
Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
/Mirran
2answers
Problem machine
Try replacing the O ring in the brew unit part number: NM01.044
Problem with Saeco royal digital plus
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
go into the menu and reduce the amount of water the machine pumps through
thanks
Coffee fix
3answers
Saeco royal professional aqua prima water filter
I think there should be a gasket in the watertank that the filter goes over.
/Mirran
Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
/Mirran
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
