The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
Finally,
check that the "Start" button was fully pressed and that a cycle was
chosen on the machine. If you do not choose a cycle for the dryer, it
will not run.
As
above, check that you have not blown a fuse or tripped a circuit
breaker. The dryer may use more than one fuse or breaker: one is used
to power the drum, and the other for the heating element. Make sure
that both fuses or breakers are in working order.
Next,
check to see if the exhaust vent is clogged. Lint and other particles
may clog the exhaust vent over time, restricting air flow and making it
more difficult to dry your clothes. To check the vent, run the dryer
and hold your hand under the vent. If you do not feel any air flow,
clean or replace the vent.
If you used cold water to rinse the
clothes it may take longer than normal to dry. The same is true if the
load of laundry is very wet or is filled with items that are very
absorbent.
Finally, check the load size. The more clothes in the
load the longer it will take to dry. If you want to reduce drying time,
separate the clothes into piles of light and heavy items and dry them
separately.
SOURCE: push the start button and nothing
Either a bad thermal fuse located on the blower box or a bad door switch .
SOURCE: I have a Kenmore 80 Series dryer. When I push the ...
Did you figure out what the problem was? I have the same problem with my Kenmore dryer.
Thanks
SOURCE: My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: 110.64872400 kenmore dryer 80 series.
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket
and remove the bracket. Remove the two hex-head screws from the lint
duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number 3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
