Question about Smeg FAB28
Smeg Fridge light
I have only had my Smeg fridge for just over a year . After a few months I noticed the the area around the light inside the fridge was warm , with a time release camera it appeared that the light stayed on even when the door was closed. The bulb needed changing twice and now even with new bulbs the light is off all the time ,I notice you sell a repacement switch for the FAB 28 but is it easy for me to fit it myself ? I don;t want to make matters worse ,I have tried writting to Smeg but they have ignored my letter.If anyone could help I would be really grateful - delving into a dark fridge has hazards!!Thanks.
  • 1 more comment
  • alex808 Jul 06, 2008
    I have the same problem (FAB28P). Can't get light to work - have replaced bulb. Spoken to SMEG who will sell me various parts but I can;t tell what I need or work out how to take mechanism apart. Anyone know how to fix?
  • Anonymous Jan 13, 2009
    I have had my Smeg fridge freezer for a year and a half. I have changed the bulb 5 times in this time. now the light doesn't work at all and i cant work out why. When you look at where the bulb goes it look like there is nothing wrong with. I to have written to Smeg over three weeks ago and i am yet to get a reply.
  • Jeannie Dorey Jan 10, 2014
    I have had EXACTLY same problem with my Smeg...only 3 years old....at first light was 'tempamental' would go on or off at will now it is continually off.....I put a small round led light you can buy in most DIY stores even in 'pound' shops...it works by battery and just sits on the inside of top shelf and when I open fridge just press it on. There must be a 'Smeg' problem with this light as a lot of people have had the same problem.....I'm sure SMEG must know of this problem...it should be sorted by them FREE of CHARGE... The fridge costs enough,.
    Novelist:
  • 87 Answers
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Posted on Jul 13, 2008
    New Friend:
I have the same problem. My fridge is never cold because the light bulb won't turn off and it is about 1000 degrees.
The design is complete crap. The front side of the light fixture is supposed to be pushed in by the door closing, thereby turning off the light.
The problem? No part of the door or shelf is actually aligned to come in contact with the light. And the shelves are not adjustable.
I have had to slap a piece of tape over the fixture to hold it in the off position (as it is spring loaded.)
I also have a giant blister on my finger from accidentally brushing the bulb. Thanks Smeg! :P
Posted on Jul 09, 2015
Phoned smeg today 5/8/2010 and they sending engineeer to look at fridge light foc. Cant argue with that. fridge 2 yr old, tried bulbs but i think needs new switch.
thanks
Posted on Aug 05, 2010
How do you stripthe light on my smeg fab 28 ps4
thanks tony
Posted on Dec 29, 2009
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Smeg fridge, light on but warm inside, thermostat?
hello my frd...this a commonly seen prb...dont worry!!!this happens bcoz there is a prb in THERMOSTAT...thats y its warm inside...thermostat s the one wch takes care of u r fridge...the best way to solve this prb s u better call u r company engineer for reparing the fridge...if u r fridge s within the warranty period...u dont want to pay him even a single penny..or else u hav to pay his service charges
Jul 24, 2009 | Refrigerators
Frigidaire PLHS267ZA Side by Side
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Smeg 50's stle fridge
we had so much frost that the fan couldnt turn to keep freezer cold. we defrosted it and it ran fine. someone left the door not shut all the way and tahats how it got wet and then refroze.
Dec 22, 2007 | Smeg FAB28
SMEG FAB28
This is a known problem with these fridges. The only fox is to replace the fridge.
Jun 16, 2007 | Smeg FAB28
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Leaking Fridge
you may have a faulty defrost timer, best consult a local dom apps store.
May 17, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg FAB28 Logo
1,657 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
