Question about Microsoft Xbox 360 Console
My XBox Jumped!
Hey my Xbox took a leap off of the table yesterday.... yikes.. not good.
Anyways, it did hit the floor pretty hard (about a 3 foot drop).
However, it is not showing any red lights. It sounds a looks fine but my TV is not recognizing the signal. Do you think that I a) damaged the whole thing, b) damaged the cable from Xbox to TV or c) damaged the power supply or D) ALL OF THE ABOVE... please help!
    Sniper:
  • 55 Answers
I would try a new AV cable
If this does not work the jolt (especially if the console was hot or on) may have knocked the gpu loose
Several fixes have been reported to work. If this is the cause you may get sound
You may have damaged the port on the back of the console where the av cable plugs in.
If the power supply lights up green and the console starts normally (green lights revolve in a circle) then it is not a power supply issue.
If you are getting 4 flashing red lights the console is not recognizing the av cable and it should be tested (this can be caused by a bad cable, or a problem with the connection from the graphics processor)
Try unplugging everything and plugging the whole thing back in minus the av cable. If you get the the 4 red lights with the cable unplugged then the console is fine and the problem is either the cable or the GPU.
If the console is still under warranty (not sure dropping it won't void any warranty it may have had, depends on how bad the cosmetic damage is) try simply heating the console (since I repair these units I don't normally recommend this, but to preserve warranty it is best to try fixes that accomplish that) using the towel trick (again please do not misinterpret me saying that as my endorsement of the towel trick, but it can cause the gpu to reconnect in some cases.
If you are not afraid of opening the console take a look inside to see if any of the heat synchs moved particularly the short one under the DVD drive.
You can try doing the xclamp replacement mod as outlined on several other websites just do a search for it and you'll find it, but you have to be precise and patient.
Best of luck
Posted on Jul 04, 2008
Mx vs atv alive says activate second controller
I guess it's as easy as pressing A or Start.
But if the controller really isn't connected anyways, you have to:
1: Turn on controller, and hold the sync button ( just to the right of the Left Bumper ).
2: Press the Sync button on the Xbox 360
> Slim version: Sync button is placed just beside the usbports on the front of the xbox.
> Original version: The sync button is placed just beside Memory Slot B ( looks pretty much as the one on the xbox controller.
3: The controller should connect and sync automaticly to your Xbox 360.
Jan 10, 2013 | THQ MX vs ATV Alive for Xbox 360
I just purchased an xbox kinnects bundle. I was doing the set up and it asked if I wanted to update so I said yes. Then the xbox turned off and will not turn back on. Please help!
Yikes...I would check to see if the power plug did not come off the xbox, then check the outlet to see if it's working, I would then remove the xbox kinnects bundle, then turn the xbox to see if its working.Then start allover. Good Luck!!
Jan 22, 2011 | Microsoft Xbox 360 Console
My hard drive has turned into a memery unit with my transfer cable and i dont know how to change it back to a hard drive any ideas please
Did you unplug the transfer cable and plug back in the hard drive to the Xbox? might have to restart Xbox afterwards. anyways the hard drive is a memory unit.
Jan 20, 2011 | Microsoft Xbox 360 Hard Drive (120GB)
My box keeps on rebuting every time i put this game in what should i do. also the red light flashes
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 15, 2010 | Microsoft Xbox 360 Console
My xbox 360s isn't working
In very rare instances I believe that the dvd drive of your xbox 360 might have been disconnected.In this case,it dispays an "open tray" message.For this you will have to open your 360 but please take it to the dealer if you are still protected by warranty.Good luck.Thanks for reading.
Jun 18, 2009 | Microsoft Xbox 360 Console
Everytime i turn my xbox, 3 red lights come up on the xbox ring, no video, no sound just the lights i was wondering if u know what to do
Yeah, well these is called "The Ring Of Death", which is pretty stupid, keeping in mind it isn't really a ring.
Anyways, out a towel over xbox 360 and leave it for 30 mins, then turn console off, then on
Jan 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless
There should have been an instruction manual that came with your wireless adapter. But anyways, you may be connected to a password protected router and need to put in the password via the dashboard. I'm pretty sure you would goto network settings and then select the network you'd want to connect to.
Dec 29, 2008 | Microsoft Xbox 360 Console
I have fable for the original xbox and it been working fine intill i took it to my friends house and played it on his xbox, then when i came home and trying to play it on my own xbox it plays the start up...
Both Fable one and two have glithches that pretty much screw up the game for good. I had a problem when i got fable one and it kept saying it had a problem ever time i tried to start it up. You can get a used copy for like ten dollars though.
Dec 06, 2008 | SG Xbox Fable (XBFAP)
Upgrade required
Hey u need 2 download it off of live! if u dont have live take your hard drive 2 som1 who does and get them 2 do it 4 u. Thats wat i did.
Hope i helped!!!!
Nov 25, 2008 | Microsoft Xbox 360 Console
HELP needed.
This seems to be a common problem without a solution. I took mine into a Sony Centre and they said that the cost of repair would be more than the units worth!
Jul 04, 2007 | Sony NW-A1000 MP3 Player
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
