Question about Hitachi 53UWX10B 53" Rear Projection Television
53UWX10B Hi, I have replaced the ICs several times(110s), first with 120s, then back to the original 110s and RK50 bad, work for awhile though pix was very dark, then started chirping/flashing pwr LED. After replacing the 110s(original) with 120s I noticed a sound similar to letting the air out of a tire, this lasted for 5 to 10 secs or so, I replaced the ICs a second time(120s back to 110s) and all 6 resistors as RK58 3.9 was open, the result was a solid pwr LED, and all 6 LEDs, 4 green and 1 red on center deflection board, and the green LED on the pwr supply board. This is when you told me to check for bad wire connections, which got my dark pic back, I thought maybe the screen/focus would get a brighter pix, I touched the red focus VR instead of the screen and the set instantly started chirping again. 3rd IC replacment(110s) worked for awhile with dark pic, then started chirping/flashing pwr LED.
  • 927 Answers
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Posted on Jul 09, 2008
It will not stay on after you power it up
Replace Both of the STK ICs,they are big black ICs and will be mounted to big Aluiminm Heat Sink
they will have part number on them STK392-110,use 120s or 150s also check all of the resistors
in front of ICs Low ohm resistors RK42 RK46 RK50 RK58.
Mats Electronics has Parts 1-800-628-1118 Ask if they have Convergence repair Kit.
Jan 28, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43UWX10B HDTV Used to work great, now when I turn it on the power led flashes and no picture. What steps do I need to take to further trouble shoot this issue?
Replace the STK ICs,they are big black IC they will have PN# on them Replace Both ICs STK392-110s use 120s
Mats Electronics 1-800-628-1118
Oct 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My tv has no picture or sound, but the power is on...
Replace your STK ICs -STK392-110s use 120s
Mats has ICs 1-800-628-1118
Sep 29, 2010 | Hitachi 53SDX01B 53" Rear Projection...
How do I fix my Toshiba rear projection tv convergence problems?
Replace both of your STK ICs, they are big black ICs STK392-110s use 120s or 150s CK all of your 1.8 ohm resistors. Mats Electronics has STKs
1-800-628-1118
Jul 01, 2010 | Toshiba 53H71 53 in. Rear Projection...
Screen looks like its in a 3D mode.
Replace Both of your STK ICs STK392-110s use 120s or 150s Mats Electronics has them 1-800-628-1118
Jul 01, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Tv does not turn own, red power button just flickers
Replace your STKs they are big black ICs will have part # on them STK392-110 if 110s use 150s better ICs also you need to CK small ohm resistors rk42 rk48 rk50 rk52 rk56 rk58 rk62.I will have to get back to you after i find correct value of resistors.
Sep 18, 2009 | Hitachi 46F500 46" Rear Projection...
Power light flasing
Replace both STK ICs use 180s if they are 110s,150s.They are big black ICs will have part number on them.
Aug 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I HAVE A 43INCH REAR PROJECTION AND EVERY TIME I TURN IT ON IMAGE COMES ON IT CLICKS BACK TO STANDBY AND THE ERROR CODE FLASHES 10 TIMES COULD YOU PLEASE GIVE ME A QUOTE OF HOW MUCH THIS REPAIR WILL COST...
Looking at 325.00 to replace both convergence ICs STKs if done by repair shop.Replace both the STKs they are big black ICs will have part # on them if 110s ,120s 150s replace with 180s.
Jun 17, 2009 | Sony Televison & Video
Blue droopy line in middle of tv, everything yellowish above
Your convergence ICs Stk-392-110s Replace Both ICs.If 110s use 180s if 020s use 040s other wise Go by number on ICs .Mat electronics has parts 1-800-628-1118.Thats Cheap for 300.00 if you only have to replace ICs! Check all resistors around ics replace them if burt/read bad.RK42 3.3ohms RK46 1.8 RK50 2.7
RK54 1.5 RK58 3.9 RK62 2.2 ohms.
Jan 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
102 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
