Question about Kenmore Refrigerators
How do you remove the water dispenser faceplate to get @ the Water line? model 57372 side by side
  • 410 Answers
If you look under the bottom edge of the faceplate or dispenser housing you will see 2 notches that you can insert a flat tip screw driver and carefully pry the cover off.
Posted on Jul 04, 2008
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
No water comming out from the dispenser
With a model number I can give you more specific direction however here is a start. Located at the back of the fridge, usually on the right side is the water valve. You can remove the plastic line that goes to the dispenser, not the supply line from the house or the line that feeds the icemaker. With this line disconnected activate the water dispenser and see if water comes out of the open side of the valve. If not you need to replace that valve. I hope this helps...
Jan 11, 2011 | Whirlpool Refrigerators
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
The water dispenser is displaced on my Whirlpool refrigerator ED5RHAX NO00. I am trying to remove the face plate but am afraid to crack it. Any suggestions?
I eventually managed to remove the faceplate, using a screwdriver in the bottom slots of the faceplate and prying it loose, sliding it up to remove it from the slots at the top of the faceplate.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Dec 31, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator water dispenser not working
My older whirlpool side by side refrigerator has stopped dispensing water. The icemaker works fine, and I have adjusted the temperature a week ago so I don't believe the line is frozen. I do not hear any noise when the dispenser is pushed down, and feel that is where the problem is. The line is clear on the bottom of the fridge behind the kick plate, but water does not come out freely when I disconnect the couplings...
Any advice?
Jan 17, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
