Question about Acer TravelMate 2500 Notebook
Black screen start up, which one hour before was working fine, but now no image appearing on screen. remaining blank, and cannot turn it off, but only by taking battery out.  power light is on and can hear the pc working.  pc is an acer travelmate 2500
  • sabinemdel Jul 04, 2008
    if lid switch is stcuk down due to closing too hard, how do you repair that?
    Master:
  • 788 Answers
Sounds like the inverter that poweres the backlight is dead. Search on eBay for the FL inverter for your model. Should be easy to replace.
Posted on Jul 04, 2008
  • Dean Joly
    Dean Joly Jul 04, 2008
    That would explain it too. The switch probably sticks out of a whole on a button cover. The button cover should snap off if you pry it up. Some notebooks have screws holding the button cover from the bottom. Experiment with he screws and something soft to use as a pry tool and you should be able to get at the switch.
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
My TV screen appears for a second then turns black, then a few seconds later appears again and the turns black again. The channel sound is perfectly fine. My Cable company tried everthing and it still...
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Jan 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Blank screen when tv switched on -audio only
definetly not.D.I.Y. its a convergance fault needs a service centre
Dec 10, 2008 | Televison & Video
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Digital Camera Malfunction
mine just started doing the same thing a few weeks ago. I had downloaded pixes to the computer, went outside to take picture and it started acting up. strange lines appear on the screen, but the codes are all there, and you can view the pictures that are on the card. no, the card is not full, the batteries are fine. I think it has a virus built in to start trouble so we will go buy a new one!
May 27, 2007 | Canon PowerShot A70 Digital Camera
Acer TravelMate 2500 Notebook Logo
187 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
