Question about Pentax IQZoom 928 35mm Point and Shoot Camera
Camera Code I have a Pentax IQZ 928. I change the battery and a new roll of film now I have a code of U7. What does this code mean?
    Scholar:
  • 185 Answers
Mimi-griffin
pentax error codes are in the repair manual.the camera must be repaired . take the camera to a camera repair shop to get an estimate for repair.
Posted on Dec 15, 2008
SOURCE:
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
Oct 22, 2010 | Pentax Espio 200 35mm Film Camera
Pentax Zoom 70-x won't take pictures, Error code E7
This is the technicians code telling the tech where to start the repair. It is time to replace this camera since the cost of repair is more than the camera is worth.
Sep 24, 2009 | Pentax IQZoom EZY-R 35mm Point and Shoot...
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Pentax 928
centuar,
pentax error codes are in the repair manual for camera repair technicians to find the problem quickly. u2-- shutter failure. take the camera to a camera repair shop for an estimate
May 28, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Flashing HI
there is a flexible ribbon cable carrying signals from camera body to the lense assembly. Due to regular use it gets worn out, thus it gets broken and is not able to perform the task for which the camera has given the signal. in your camera also the same flex cable is broken. Get it changed at some good repairer
Oct 26, 2006 | Pentax IQZoom 928 35mm Point and Shoot...
U3 and u7
I wish i could help you, but Pentax's manual is poor and many people (over the net) face Pentax error message with no meaning... Try replacing the batteries if you haven't already, if it doesn't help I would take it to a local camera repair shop. If they can't help you call ProCamera in harlottesvile VA. He collects pentax owns his own shop. He's been in business for 12 yr's and he is also a succesful photoghrapher. I've heard nothing but the best about this guy Bill Moretz. I have a pentax if anything happens to it i know where i'm shipping it of too and pentax is the only camera i will own. His prices are right so the shipping costs are worth it. Good luck
Jan 23, 2006 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Pentax IQZoom 928 35mm Point and Shoot Camera Logo
252 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
