Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer easy share 5100
Elictric getting through to control panel only the on off switch works rest of panel closed down purshed 3/2/08
    Master:
  • 788 Answers
Contact Kodak for warranty service.
Posted on Jul 04, 2008
Cannot figure out how to get out old printhead from kodak easy
Remove ink cartidges and press on taget up on top of printhead. It's clipped in and just pull out.
Mar 20, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Need software to download for kodak easy share 5100 all in one
Well, then u need the drivers NOW..:) and here they are:
http://www.kodak.com/global/en/service/products/ekn033539.jhtml?pq-path=9098
You see the drivers to the left on the site.
I hope this will solve your problem.
Good luck to you!
please take a minute and rate me
Nic
Feb 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
Jan 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Sharing a Kodak 5100 All-In-One Printer
try this.............
On the computer that is connected to the printer:
  1. Open the Control Panel.
  2. Select Printers and Faxes.
  3. Right-click the KODAK All-in-One Printer, and select Properties.
  4. Select the Sharing tab.
  5. Select Share this printer.
  6. In the Share name field, type a name for your printer.
  7. Click OK.
  8. Right-click My Computer and select Properties.
  9. Select the Computer Name tab.
  10. On a piece of paper, write down the full computer name as it appears on the screen (for example: Johns Computer).
    NOTE: This is the name that you enter on the other computer(s) to access this printer.
On the other computer(s):
  1. Select Start > Run.
  2. Type two backslashes (\\) and the full computer name as it appeared on the first computer (for example: \\Johns Computer).
  3. Click OK.
    A window shows the new printer as the Shared Printer.
  4. Double-click the printer.
  5. Close all windows, then print to the Shared Printer.
Let me know if this helped.........
Dec 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Cannot find a default setting for scanner
by chance, is that printer plugged into a power strip? that can make a scanner NOT work.
http://tinyurl.com/6qcpgy
Jul 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My easy share 5100 all in one keeps telling me it is disconnected from my pc. i have checked the cable and my plug in. i can also print from copy mode but i cant print from my documents. or my pictures ,...
Try this:
> Unplug the printer from the usb port.
> From the Control Panel > Printers, remove all printers.
> reboot.
> reinstall the drivers
> plug the usb cable back in.
Hope that helps...
Geno
Mar 04, 2008 | Computers & Internet
Installation
I work for kodak and this is actually a very easy fix.
The MAC OS 10.4.11 won't install off the cd only the website.
The cd sees that the OS is 10.4.1 not 10.4.11 just a glitch and the fix is installing from the website.
And no you need at least 10.4.8 to run the kodak printer on macs.
Dec 23, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
