Question about Brother Office Equipment & Supplies
Machine Error: 5A - Brother Office Equipment & Supplies
I have a MFC 240C and got the 5A "read the manual" can't print error. A paper jam had occurred and knocked out a piece of plastic/door on the back of the printer. I cleared the paper jam from the back by gently pulling out the paper, replaced the plastic part in the back of printer. Then I pulled the front paper loader out- looked around in there for paper scraps from the front, and put that back in. It still would not print. Then finally I opened the ink door (front right) and pressed each ink cartridge as if to take them out, then pushed them each back in and the machine was fixed.
Posted on Jul 22, 2008
    Master:
  • 788 Answers
This is most likely a fault with the purge shaft and is not worth fixing if the printer is worth less than $200.
Posted on Jul 04, 2008
Machine error 5a
try instead 2783 ....2864, 4460, 99
Jul 23, 2014 | Brother Network-Ready Multifunction...
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
Unable to clean, error 5A. Already reset purge counter. Print head clear of any obstructions and moves properly. Unable to determine what error 5A is.
Hi Jason, 5A is usually caused by a bad maintenance unit. The purge cam gear may be broken or too much load on the maintenance unit. Either way replacing maintenance unit should solve the problem.
Aug 19, 2013 | Brother MFC-3240C All-In-One InkJet...
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Hi i m using brother printer i am getting error code of 5A
Hello Ankit,
The error 5A you are receiving because the machine does not work due to a paper jam or some sensor problem.
To resolve the paper jam issue visit the link provided below :
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_002.html?reg=us&c=us&lang=en&prod=mfc210c_all&Cat=11
Jun 22, 2011 | Brother MFC 210C All-In-One InkJet Printer
Error 5a in brother dcp 130c
5a says the purge assembly is stuck, you need to pull the printhead out of the right corner and check for paper scraps or debris. If the printhead is stuck, don't force it, just power up and wait for the head to come out and unplug the machine. Check inside on the right with a flashlight and remove any scraps.
Oct 02, 2009 | Office Equipment & Supplies
Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Jun 29, 2009 | Office Equipment & Supplies
Need to reset purge counter due to error 46
not easy and worth to fix it since ink jet printer sare cheap. New one include all the ink cartridges which are expensive too.
gar266
Jul 30, 2008 | Brother MFC 420CN All-In-One InkJet...
I have an error 5A in my dcp-110c
Purge unit error. Check for a piece of paper in the purge unit - right hand side of printer where the carriage sits. Trick the machine by powering off while carriage is moving and check for paper under the cover. If no paper there is a problem you can not correct and you need to get it serviced.
Jan 04, 2008 | Brother DCP-110C All-In-One InkJet Printer
1,642 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
