Question about Husqvarna Viking 1
My Husqvarna Viking 775 will only sew backwards this morning. I have tried unplugging and replugging in. Any suggestions?
Have you tried turning the plug in around to a 180 degree turn?
Posted on Aug 22, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
You should have it checked by a certified Husqvarna repair facility. It may have a problem with the stitch length motor.
I think that model will turn off the reverse lock if you shut it off and back on so that isn't it.
Have someone check the feed length motor to see if it calibrates when the machine is operated.
Posted on Aug 21, 2009
I have a husqvarna design 2 but the machine sewing is going backwards any ideas on how to reset and make it go forwards ?
The feed mechanism stepper motor probably needs replacing. The cost of the part is usually around $150. It will have to be done by an authorized Viking Dealer You can find your local dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Jun 02, 2014 | Husqvarna Designer I
The light turns on, but the machine doesn't.
it would be a good time to have the machine and the foot pedal checked.
Apr 25, 2013 | Husqvarna Viking 1
Stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website http://www.husqvarnaviking.com and selecting "dealers" link.
Feb 11, 2010 | Husqvarna Viking 1
My machine will not pick up the bobbin thread when sewing. I have a Viking Husqvarna. The stitch setting will not hold and the stitches are about 1/4" apart. You can pull them out with no problem.
I read on line that the needle may be in backwards. Not sure that was true, but I did take it out and re-insert. The machine sews just fine.
Thank you,
Lavon
Dec 20, 2009 | Husqvarna Viking 1
Machine sewing backwards only
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Sep 23, 2009 | Husqvarna Viking 1
OUR Husqvqrna 5310 suddenly started sewing backwards
Problem is probably with the feed stepper motor or the reverse cams are locked. What happens when reverse button is activated. If no change it's probably the feed stepper motor. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Sep 12, 2009 | Husqvarna Daisy 310
Husqvarna viking Platinum 775 fabric won't advance
Most of the time the bobbin case gets hung under the feed dogs, take your needle plate off and the bobbin cover there is a gray colored finger with a number 10 torx screw holding it in you can also try a small flat head screw driver, remove that finger and then remove your bobbin clean the hook out and replace the bobbin making sure it seats itself on the hook with the small notch on the bobbin case lining up with a small metall spring on the back right side of the hook area.
Jun 07, 2009 | Husqvarna Sewing Machines
Husqvarna sewing machine - viking 400
HI,
Do you mean how to retime it?
Jun 11, 2008 | Husqvarna Viking 1
Sewing Machines Logo
96 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
