Question about Dryers
We moved in to a new house in Nov. 07 Have a Bosch 500 series dryer (new) The dryer stops after a few minuets and a signal sounds, error shows on display, and states clean filter. The filter is not dirty,(I clean it) filter has been washed 3 tims since Nov. 07(when purchased new )Have vacuumed in the vent space in the dryer.Cleaned senors with vinegar. Removed hose and it is not clogged. Not up against wall, for proper ventilation. Please help
  • 525 Answers
If the dryer worked fine at the old house, I would suspect a wiring or grounding issue could be causing your symptoms.
Electronic controls often exhibit erratic behavior when not grounded properly.
Tip: To save you money, whenever an appliance is moved from 1 location to another, and an issue like this arises, do a thourough electrical and vent investigation before contacting a service provider.
A new dryer will sense a venting inadequacy and give an error code. Investigate your venting system thoroughly. Below are some helpful tips on investigating a vent inadequacy. Always consult your user’s manual before contacting a service provider.
Below are some tips that will aid you in investigating your vent issue.
  1. Do not rely on visual evidence; clean the vent from one end to the other. If possible, remove the entire vent tube and take outside to run water through it. Brushes of different lengths are available from parts suppliers if you cannot remove your venting.
  2. Do not rely on apparent airflow velocities. All dryers use different airflow velocities and minor obstructions are not readily observed optimally without utilizing an anemometer, (air pressure/speed gauge).
  3. Disconnect the dryer from the vent and run a load to eliminate, or suspect, the vent as the cause. If the dryer performs normally then the vent is the cause.
  4. Water can condense in a flexible vent tube and cause sagging. This needs to be eliminated by replacing the vent with rigid ducting if possible, or by bracing the tube. There are numerous venting accessories and options available to optimize the venting of a dryer.
  5. Dryer manufacturers use varying combinations of blower speeds, tumble revolutions, heat temperatures, and sensors to achieve a favorable result.
  6. Always remember that the shortest and straightest vent is the best vent.
  7. The lint filter could be coated with an invisible coating from using fabric sheets in the dryer. Hold the filter horizontally under running water and if the water beads up and does not filter through, replace the filter, and stop using fabric sheets. This same invisible film can also build up on sensor bars and cause drying issues.
  8. Animals, snow, shrubs, etc. have been noted to occasionally restrict the air from exhausting to the outside, by blocking the exterior vent cap. Be sure and check this frequently, especially on cold days, as animals love to be near a heat source.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
My Bosch Nexxt 500 series dryer shows an error code of E:22. I'm hoping u can tell me what it relates to. The photo shows what it is doing. Start light and filter light flash but it won't turn on.
E:20 through E:26 Defective control module Unplug the dryer for 3 minutes to reset the control module. If the code returns when power is restored, replace the control module. Control module
Nov 03, 2015 | Bosch Dryers
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Bosch nexxt 500 series dryer producing intermittent gas smell when running. wife says the smell has even permeated the clothes a time or two, but I haven't noticed it. heat exchage box? if so, how hard...
A few things to check...
First, check that the dryer vent is not clogged. You'll have to go outside to check. If you are not sure of a clog, disconnect from inside and have your wife hold a flashlight by the vent, then go outside to see if you can see it. This will also cause laundry to dry slower than it used to (your wife may have a feeling if this is the case).
Second, make sure you don't have negative pressure in the house (large house fans are good for cooling but move too much air out so the dryer cannot vent its exhaust gasses well). You can check by opening an exterior door about an inch and check if it swings open with a gush of wind. Even houses without whole-house fans can do this if you have enough bathroom fans and furnace fans going.
Third, If it is a smell of natural gas, then you should call a service technician because the valve is not opening/closing correctly (or fast enough) if you have a pilot-less starter.
May 05, 2011 | Bosch Nexxt 500 Dryer
Our start button is flashing on our bosch nexxt series dryer, but when depressed it doesn't start the dryer. We have just moved it into a new home.
Here is what happened to our nexxt dryer. So this may be the problem with yours. Our dryer is about 6 years old. The start/stop button was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Dec 12, 2010 | Bosch Nexxt 500 Dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
149 people viewed this question
Top Dryers Experts
