Question about Samsung Televison & Video
Samsung sp43w6hl..the colours are vague and the images double up..i was told the lens needed cleaning up..havnt got a clue..need sum urgent assistance plz
4 Suggested Answers
  • 65 Answers
SOURCE: need to adjust lens focus on all three projectors
If its a double image that sounds like convergence.
Posted on Apr 09, 2009
SD Tech
  • 14553 Answers
SOURCE: gettung double imaging with blue and yellow
Double check the model number---there is a 61swx10b---All of these sets use two STK-392-110 convergence chips.
Check my recent posts and you will find similar ones related to your TV. Both chips need to be replaced and you can buy them on Ebay for less than 20 dollars for a pair including shipping. Depending on how they fail there may also be a damaged resistor located near them.
If you cannot do this repair shop around your area as most shops will try to charge 300-400 for this repair.
Make sure whoever you get replaces both chips or you will shortly have the same problem again.
I have done hundreds of these sets and here charge 200-250 for this kind of repair. If a shop tells you it has "to go to the shop" keep looking as any good tech can do this repair right in your home in about 1 hour.
I hope this information has been helpful and if you have ANY questions or need advice contact me.
SD TECH
Posted on Sep 25, 2009
Ecollier2012
  • 3459 Answers
SOURCE: double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 24, 2009
My samsung 67 in flat screen has a double picture and I have no idea why. An example would be: it it says weak signal the display shows it like so "weak signal" "...
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB8QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dj7vl7-vZEL8&ei=1Dl0VKbHCobEmwWHyYL4DQ&usg=AFQjCNEAyKFYUTGQJSdIJHNNQNODhqatWQ&bvm=bv.80185997,d.dGY
That YouTube link may help as it deals with the double image problem on a Samsung LED TV. It should at least give you a clue about the nature of the problem. You might have to try Samsung's tech support otherwise. I don't think this is a matter of needing some 3rd party signal amplifier because I figure you are using cable TV if you paid a bundle for a set.
Nov 25, 2014 | Televison & Video
Intermittent color problems
Printer heads could need cleaning or are damaged. Try several cleaning cycles, if that doesn't clear up the problem change the color cartridge.
Nov 12, 2013 | HEWLETT-PACKARD Hewlett Packard Color...
Samsung n130 reset
power on laptop and when boot logo appears on screen suddenly tap(press) the F4 key. You will be guided to the restore option screen. There you can select complete restore. If you need to back up data you can do it before restoration process otherwise whole data will be wiped off. Cheers.
Dec 02, 2012 | Samsung N13013B Netbook
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung sp43h3ht and the colours gone
sounds like the color wheel needs replacing if the image moves on the screen, or if the image is frozen it would be the dmd board.
Nov 11, 2009 | Samsung SP55W3HF 55" Television
I was just given a samsung hcp4752wx/xaa. The
OK, Its always best to replace the lens assembly if its not preforming well. never dump the fluid. just replace the lens. As for the double images and the misalignment of the blue convergence line, this is caused by a faulty convergence chip that is located on the convergence board. you will need to replace this board in order to restore proper convergence performance.
May 16, 2009 | Samsung Televison & Video
Sony faded colours and double lines
You probably need to replace the convergence IC's and do a good cleaning of the internal mirror and lens. This repair will involve soldering and un-soldering on the printed circuit board. If you have no printed circuit board repair experience, play it safe, and have a pro do this repair for you as that price sounds reasonable for this type of repair. Good luck!
Apr 13, 2008 | Sony KP-51WS500 51" Rear Projection...
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Televison & Video Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
