Question about Amana ALG331RAW Gas Dryer
Dryer heating problem
Dryer not drying cloths, removed front, ignitor comes on flame ignites then after dryer heats it shuts off. Then ingitor glows again multiple times and occassionally the gas will ignite but not everytime the ignitor glows. Do I have a airflow issue or something else going on?
  • 5 more comments
  • sportiweber Jul 19, 2008
    when dryer finishs cloths still feel damp
  • help5000 Oct 13, 2008
    how do I correct my air flow?
  • garj4u Nov 16, 2008
    have the same thing happening to my Hotpoint gas dry. igniter lights flame and runs for about 5minutes them flame goes out and seems like it has trouble lighting after that even though igniter still works.
  • ghuffman164 Apr 27, 2009
    electric dryer heats but does not dry the cloths
  • Michael Barringer May 19, 2013
    I checked my airflow, theres no blockage, any other ideas?
  • Anonymous Mar 20, 2014
    DV337
  • Anonymous Mar 25, 2014
    it stopped heating up. I can't see any flame through the front peephole.
    Could it be the ignitor?
    Problem Solver:
  • 14 Answers
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Posted on Jul 25, 2008
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Dryer runs....no heat
Make sure the lint filter and the exhaust vent pipe are not clogged.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 21, 2009 | Refrigerators
Dryer does not heat
Nov 04, 2009 | Video Cameras
Dryer not drying clothes
If the load is extremely large or heavy it may require more time. If you have an auto sensor cycle try that. If you are using the auto cycle and the clothes are not drying then the sensor may be not operating correctly. Make sure the lint filter is clean and that the exhaust vent duct is not clogged. Check all the way to the outlet. If all is clear then the thermostat2.gif may need to be replaced if it is not calling for heat as often as it should. Also check to make sure there is air flow from the vent. If not then the fan/blower may be broken or disconnected from the motor shaft.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Oct 21, 2009 | Whirlpool Dryers
Dryer turns on, tumbles the drum but does not ignite the gas unit to heat and dry clothes
Sep 21, 2009 | Dryers
Not heating up to dry the clothes dryer is coming on and off fine its just not getting hot
Make sure the lint filter is clean and the vent duct is not clogged. Check all the way to the vent outlet. Then: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat or the auto sensor is not working correctly.
Sep 15, 2009 | Dryers
Not drying clothes not producing heat
Aug 26, 2009 | Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
I ran the drier 3 times using medium press. The heat is on and it is hot, but the clothes is not dry.
Hi, Does this dryer heat at first and then stop heating late in cycle?
Remove the lower front panel and start the dryer. Look and see if the ignitor glows and if you get a flame or not. If the ignitor glows and then shuts off before you get a flame, the coils on top the gas valve need changed.
If the ignitor does not glow, UNPLUG the dryer and check the fuse located on the blower housing (whits with two wires going to it). Check and see if it has continuity to it.If there is no continuity, change it.
Please let me know if this helps you so far.
Vic
May 30, 2009 | Whirlpool GGQ9800PG Gas Dryer GOLD...
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Amana ALG331RAW Gas Dryer Logo
601 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
