Power comes on thin kicks off - Televison & Video
  • 8,617 Answers
I would need the model number and more info such as does the power light go off? Does it blink if so how many blinks.
Posted on Jul 04, 2008
Wirring dagram for starter reay cilinoid
There is only two wires and they can't be reversed. One is fat and comes from the battery the other is thin and comes from the starter switch. power to the thin wire excites the solenoid and the motor turns.
Jul 14, 2014 | 1984 Honda GL 1200 Interstate Gold Wing
2012 honda cr v disarm wire location
The disarm wire is in the driver kick panel, in the harness coming in from the driver door. It's a thin brown wire.
Dec 07, 2012 | Remote Start System
My computer pc boots and goes off after a while
Sounds like it might be overheating or a virus is kicking you off. If it is overheating, then if you try to immediately try to power it back up, it will not come back successfully. If you let it sit a while and cool off then power it up and it boots successfully then you know it's overheating.
Causes of overheating:
1). Dust - dust in the fans, the vents, around the heatsink and cpu, all inside the computer.
2) A Fan that does not work.
3) The Thermal Paste around the CPU and Heatsink has either dried up or is too thin to keep the unit cool.
Good thing it's a desktop, cuz all you have to do is remove the power cord, the case and you can remedy the problem easily.
Apr 03, 2012 | Computers & Internet
Compressor kicks on then reset trips after short while. only pumps about 20 psi each time i push the reset?
How far are you from the power source. The compressor draws a lot of power, if the extension cord is too long or the wires in it are too thin, the compressor will have run issues.
Have you plugged it in close to the main circuit panel and tried it there.
Feb 01, 2011 | Makita MAC5200 Electric Powered Air...
My kx 125 was going well then lost power and now can not move kick start at all . how do i tell if the engine is siezed
sounds like it seized! if the kick starter wont go down. take the spark plug out, pour some thin oil down the hole, let it soak overnight, then try moving the kick starter again.
May 09, 2010 | 2005 kawasaki KX 125
Of glass defroster rear of my car chevrolet cavalier 2004, is not working I checked the fuse box and are well need help to fix this.
Check the bigger metal leads that connect up to the thin rear defroster grid. Often there are crack lines that result in no electrical conductivity. There are repair kits available to remedy this or you can try to carefully re-solder the bigger leads but you may need the kit for the thin lines.
Dec 03, 2009 | Chevrolet Cavalier Cars & Trucks
My 2004 Tahoe is not shifting in to gear unless I come off the gas some. The speed dail started to stick before this issue started. any ideals.
Instead of a cable, most vehicle's speedometers are controlled by a speed sensor at the tail of the transmission. These do go bad and would cause your speedometer to malfunction. They are not like light bulbs which just die, these sensors will kick in and out irregularly.Secondly you have a thin cable that is connected to your throttle in addition to the throttle cable itself. This second cable is for the kick-down of your transmission. It is utilized when you make a sudden pass of another vehicle to shift down one gear. This cable becomes misaligned at times and will, in a sense, become shortened. Try releasing it from the throttle cam and see how your vehicle reacts then. If it shifts correctly than you need a new kick-down cable.
Sep 06, 2009 | 2004 Chevrolet Tahoe
The screen on my compaq Armada 7770dmt is broken is there anywhere I can get a replacement part.
Yes you can buy a replacement screen from ebay alot cheaper then from the manufacturer. They are quite easy to replace but becareful and gentle when it comes to replacement and make sure all power is removed before attempting to change the screen as the inverter which is a long thin circuit board under the lcd screen gives out a hell of a kick as its a high voltage part
Aug 22, 2009 | Compaq Computers & Internet
Need help fixing tv
Read the post by tarnoldsr here: and $5.00 later you'll be back up and running!
May 25, 2009 | Akai LCT2785TA 27 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
