Question about ASUS K8V-MX Motherboard
Urgently send me solution with diagram
How to connection panel wire hdd swf, rst , pwr in a specific places
    President:
  • 1,114 Answers
Hi - Here is the diagram from the manual:
Hi - You can download the manual from the link below:
Manual
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 04, 2008
    Sergeant:
  • 287 Answers
This LINK will take you to the asus site. click on "manual" and select the appropriate manual from the list to download
Dell motherboard diagram of wiring and front pannel connectors
most front panel connectors with a 4 x 5 pin configuration are intel compliant, and are all the same.
The "nine" pin is missing, and is the "KEY" to orientation, no matter which way the pins are situated on the board.
1 3 5 7 X
2 4 6 8 10
1= HDD LED+, usually green
3= HDD-, usually white or black
2= PWR LED+, usually red
4= PWR LED-, white or black
These are polarity specific, and must be connected to the proper + and - terminals to work properly
5= RESET
7= RESET
9 is missing, can be used to determine location of other pins
6= PWR
8= PWR
Thes are momentary contact pins, can't get them backwards
Pins 6 and 10 are jumped together in the Dimension 2400.
Apr 18, 2014 | Dell Dimension 2400 PC Desktop
ASUS MOTHERBOARD A7V8X-X FRONT PANEL WIRING DIAGRAM
Most of the wires on the front panel are just for LED Lights other than the Power Button. Look on the motherboard for the abbreviated spellings of PWR for the Power Button, RST for Reset, HDD for Hard Drive, etc. Only the PWR will keep your system from booting up. If you place the others on the wrong set of pins the Led light will not illuminate.
Jun 02, 2012 | ASUS Computers & Internet
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
Problem with the MSI 7050 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
Sorry, I can't find a color diagram. But check page 2 of the HP support manual, this shows all the jumpers and board connectors. You can download the manual from the link below:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00358730/c00358730.pdf
May 20, 2011 | MSI K8MM-V Motherboard
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
Hooking up case wires to motherboard: ECS M925
If you look at this picture, the pins on the motherboard should be on the far left below the brown slot and above the white connector. The pins on the board are marked with tiny white letters HDD, PWR, RST, SPKR. The USB connection on the board may require a separate header, I can't find a manual to see for sure.
Apr 04, 2009 | PC Chips (M925G) Motherboard
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
Nov 30, 2008 | E-Machines (308714) Motherboard
Atx power swtich replacement
Either way will work! No worries, it is just a switch. Just think about it. A jumper wire would work as well, right?
Oct 20, 2008 | ASUS Terminator PC Desktop
Front panel connections
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
ASUS K8V-MX Motherboard Logo
150 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
