Question about Indesit Washing Machines
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
  • momoxx Jul 07, 2008
    fixed the problem ,turned out to be,the pump was full of coins,nails,hairslides.now working a treat.
    President:
  • 1,462 Answers
Probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Posted on Jul 05, 2008
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Indesit w113 and w1101 wasing machines dial clicking round
This type of fault is usually associated with a faulty programmer. if you have a reset point, then try to reset it, if no reset, then programmer is faulty.
Please rate my solution.
Thanks.
May 11, 2009 | Washing Machines
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit w1 13 reset
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
Nov 06, 2008 | Indesit WA 115 Front Load Washer
Indesit w143uk
these machines are a problem! the dial clicking round can be a component fault - ie pump etc - or a module fault. from what you describe, fault could be with the pump. an easy way to check is to power the pump up independently and see if drain works ok. (i assume you have checked the filter) after that, check continuity in the heater as well. if both of these are ok, you are faced with a module fault
Jul 21, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
404 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
