Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox P16 error
Hi, this is the error, position value may change every time, but line 226 is always the same. It occurrs when printing from any software, even from testing printing from printer driver.
Please help me
internalerror-false
position:0x33cb(13259)
system:h6fw/xl_pa
line:266
version:qpdl 1.22 12-022003
    Scholar:
  • 136 Answers
What I would do is go through the Menu program and delete ALL of the memory programs complete look for system data then scroll through the memory and delete all the Memory this is where i would start first, By the way "Samsung" made this product for Xerox so this is technically a Samsung Product.
Posted on Aug 04, 2009
Cannot get black cartridge to print. I've checked everything...cleaned printer head.
Press the Resume/Cancel button.
- If paper is being fed at error occurrence,
the error is indicated after the paper is
ejected.
- If the error occurs, the print head
alignment values are not changed.
- After exit from the error by the
Resume/Cancel button, the automatic
print head alignment will not be re-done
Aug 23, 2011 | Canon PIXMA® MP460 All-In-One InkJet...
Why does my scanner cannon mp160 scan reverse image
ejected.
Aug 23, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP180. U051 error. How can I reset ? I tried already that combination of reset and power button but nothing.
ejected.
Aug 23, 2011 | Canon PIXMA MP170 All-In-One InkJet...
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Put a brand new maintenance kit in Xerox Phaser 8560 and it died
This is from the service manual. The lobes on the camshaft that rotates the maint kit up are know to crack. If they have rotated on the shaft this could cause your problem.
If you remove both sides and home everything it will come ready as long as nothing is broke
Harry
The 7,007.49, 7,008.41, 7009.42, and 7,010.43 errors indicate that the
Printhead was unable to tilt normally on its axis. Possible causes include:
??  The printer was powered off in the middle of a cleaning cycle and the
Wiper Blade has frozen to the Printhead.
??  A Drum Maintenance Camshaft lobe is broken and holding the Drum
Maintenance Kit’s oil roller against the Drum when it should be retracted
to its home position.
??  Process Drive not being aligned correctly.
??  A damaged Printhead Restraint.
??  Ink spilled in the Roll Block preventing proper Printhead motion.
??  Ink or other debris under the Printhead preventing proper motion.
??  The Wiper Assembly not being aligned correctly or ink spilled in the wiper
tracks.
??  The Head Tilt Gear not being homed correctly.
??  The X-Axis Motor nose cone not being installed correctly.
??  The ferrite torrid on the Printhead interface cable has slipped behind the
Printhead causing the Printhead to bind when it tilts backwards.
??  The black plastic shroud on the back of the Printhead is snapped off and
binding the Printhead when it tilts back.
Caution
After servicing the printer, manually set the following assemblies to their
home position before powering on the printer. See Section 6 for
instructions on setting these components to their home positions.
??  Printhead (tilted forward and disengaged from Printhead tilt gear)
??  Head Tilt Gear (disengaged from Process Drive train; arrows on left
frame point to each other)
??  Wiper Assembly (bottom of travel)
??  Process Drive (holes on Transfix Camshaft and Drum Maintenance
Camshaft line up with marks on frame, large gears within assembly
line up with holes in Process Drive housing)
Oct 21, 2009 | Xerox Phaser 8560DN Laser Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
Error code b300
be re-done.
Oct 08, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Xerox Phaser 8560 - error code: 07,010.43:205458
This is from the service manual. If you remove both sides and home everything it should come ready.
Harry
tracks.
Caution
Apr 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WC Pe16 ask for solution for Internal error false... line 226
INTERNAL ERROR - FALSE
POSITION: 0x4364c (276044)
SYSTEM: H6FW/xl_image
LINE: 495
VERSION: QPDL 1.40 11-14-2005
Jul 03, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
453 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
