Question about Frigidaire FRS23R4A Side by Side Refrigerator
Fridge is popping my GFI switch
Out of nowhere my fridge is popping the GFI switch. The weird thing is I can reset it, and it will be OK for hours.....then pop. I've isolated the problem to the fridge by having it as the only electrical compoent plugged into the circuit, then by pluggging it into another kitchen circuit with GFI. POP. I've removed the back cover and cleaned out all the (cough, cough) dust and inspecd the outlets as well.
  • 1 more comment
  • strok
    strok Jul 05, 2008
    The fridge was not plugged into the GFI outlet directly. It was plugged into a 'normal' outlet with a GFI in its circuit. Also the fridge has now lost its cooling ability, both freezer and fridge are room temp.
  • RTVan Jul 26, 2008
    Same problem - popping gfi after 5 years of normal operation. Works fine when plugged in to 'normal'outlet, but I'm wondering if it is drawing more current than it should?
  • Mr Hytech Nov 17, 2008
    Same problem after years of running OK (popping the GFI circuit breaker). Not a side-by-side, but it IS a Frigidaire. It started the night before Thanksgiving last year. Because we needed the fridge to store extra food for the next day, I had no time to fix it - just find a way to keep the breaker from popping. We normally use it for beverages by the bar, not food. I was lucky to have isolated it to the icemaker right away. I disconnected the icemaker's power plug in back of the fridge to stop the breaker from tripping. A previous comment was that refrigerators are not supposed to be plugeed into GFI cicuits. Not true. With very few exceptions, anything with a grounded plug must be able to work with a GFI circuit. The exceptions include certain items like guitar amplifiers, which have a "grounding" switch to reduce hum, etc (but that's another subject).
    GFI's work by sensing a difference in current flow between hot and neutral. Everything "going out" on the hot line must "return" on the neutral line. If not, that means some of the current is "leaking" to ground, and the GFI circuit senses the imbalance and shuts off the power.
    I suspect that there is a path from the hot side to ground through some water that may be leaking, or ice that was built up where it shoudn't be. If it was a short circuit, the GFI would trip instantly, but it doesn't.
    Off I go to tackle the job...
  • 410 Answers
Refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Posted on Jul 04, 2008
  • peyton thompson
    peyton thompson Jul 05, 2008
    is the refrig running at all (fan motors running, lights on etc.)? if so pull the rear cover off of the unit exposing the compressor and check to see if its running. its possible that since it kicked the gfi and has since quit cooling that the compressor has gone bad. let me know any other things that you notice such as strange noises or anything out of the ordinary so that i may point you in the correct direction..
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
What would cause intermitant pop of ground fault. only thing on the line. ground fault has been replaced
Refrigerators are not recommended to be plugged into a GFI outlet. Depending on the age of the fridge there will be spikes in the current the fridge uses at certain times causing the GFI to trip. A GFI outlet is much more sensitive to current than a non GFI outlet that is tied back to the the regular breaker in the electrical panel. Pleazer Appliance...
May 06, 2014 | Whirlpool Refrigerators
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Westinghouse RJ442 fridge was working now tripping
Is it a GFI that it is tripping. If it is using an extension cord try plugging into a non GFI outlet.
Feb 03, 2010 | Westinghouse Refrigerators
My frig will be working fine then it trips the GFI outlet. you reset the out and it will trip it again a few minutes later.
Why do you have your fridge plugged into a GFI outlet? It is not necessary if the outlet is hidden by the fridge. A GFI is only used where an outlet is within 6 feet of water and is out in the open. I would replace it with a new regular outlet.
Sep 14, 2009 | Refrigerators
Side by side running all day door left adjar. blew gfi reset but not running is there a reset button for the compressor
It could have popped the gfi plug , when in defrost . It can draw up to 6 amps in defrost . Use an extension cord to another outlet not gfi . If in defrost when popped , after plugged in for a little while (28-32 min) , it should cycle on . I wouldn't leave it permanently on extension cord , but replace that plug behind fridge to a normal plug (not gfi) .
Aug 27, 2009 | Whirlpool Refrigerators
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Jan 24, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
2,059 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
