The error message is telling you that the recovery utility was not
able to read the data from the disc correctly, or wasn't able to write
it to the hard drive. The problem could be with the disc, the CD/DVD
drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using
another system. If you can't copy it, order replacements from Toshiba
Customer Assistance: 1-800-457-7777. If you can copy it, try using the
copy to do the restore.
You can try using a third party disk
checker to verify the problem is or is not with the hard drive. But
since the system is under warranty, you're going to have to arrange to
have it repaired anyhow, so it may not be worth the effort to verify
whether it's the hard drive or CD/DVD drive. It's probably not the
CD/DVD drive since you got all the way through the first disc. Contact
a Premier (not regular) ASP for service from here:
http://pcrepair.toshiba.com The
best way would be to load the Win Vista discs n format the pc...and
reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD
with you but the Vista Recovery Boot Cd is available free by Microsoft
just google...
Download it burn the Image .iso and run
that disc. Since that disc will not restore the OS all it does it lets
u run diagnostics on ur HDD and allows u to install the OS. Once disk
check is completed and repaired, proceed with the Recovery disks that
you have.
thank you
have a nice day
