Back to:
Tags:
Technics SL-1210M5G Turntable
Platter jurk
posted by teetec on Jul 04, 2008
All the lights go out except for the on/off switch and the platter moves to and fro but does not turn, almost like two magnets passing each other, had a problem with the pitch, now go due to new board and pitch, was wondering if that had anything to do with it as was fine up until the pitch went
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 12, 2008
FixYa! (100)
djproaudio
Rank:Guru Guru
Rating: 88%, 145 votes
Not a pitch issue. This is a drive issue. The drive circuits are located underneath the turntable platter, on the main PCB. They usually go bad, more recently then before, unfortunately.
Not an easy fix, but not an expensive fix either, as the components are relatively cheap. It is time consuming, and if you have someone work on it who doesn't know what they are doing, could run up a nice tab on the repair. So be careful where you take it to. Ask them if they've worked on Drive Issues on 1200s before. If they look at you like, huh? STAY AWAY.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Platter jurk:
I don't want to Accept this solution
Can you Help with these Turntables problems?
Turntables
the drive belt has come off. how can i put it back on to...
Turntables
Dear davejuke01, Thank you for telling me about the brush...
Turntables
Hi, Have a home stereo system with different components,...
Turntables
need a motor for my turntable..it is an old system but in...
Turntables
When I push the power button it doesn't come on.
Loading problems.
Repair Service
Find Turntable Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
