Question about Samsung J750 Triband Black Unlocked 3G Phone
Samsung PC Studio 3 will not recognise my new phone connecting to my pc by usb cable
  • 3 more comments
  • Bengt Aug 27, 2008
    I have just bought a Samsung Soul, and connection with my computer and PC studio, does not work in the "PC-studio mode, but synchronization with Windows mediaplayer and mass storage to the external memory works well.
  • mickdi Nov 03, 2008
    When I connect my mobile phone to the computer, the battery starts to charge, but Samsung Studio 3 version 3.2.2HG5 says It is not connected . I am working on Vista and have; I believe downloaded the latest software. Can you please help. My phone SGH-A701
  • guimeimei Nov 11, 2008
    When I connect my mobile phone to the computer (Windows XP with service pack 2), the battery starts to charge, but Samsung Studio 3 version 3.2.1HG6 says it is not connected . My phone SGH-U900.
  • Anonymous Dec 03, 2008
    Hi, I have a SAMSUNG J706 and have same problem.
    Last version from PC Studio 3 and a update of USB Driver and is not functionnal again... Anyone have an solution ???? :-(
  • Anonymous Apr 21, 2009
  • 3 Answers
-OK...when you download the PC Studio software, be sure to save it to your computer first and then open it from your computer, this way if anything goes wrong you can always reinstall it. Alright, make sure the phone is NOT connected via USB during the download of the software. Next, go into your phone menu under 'Settings' then select 'Phone Settings' -go to 'USB Settings, usually there are 2 modes 'Mass Storage' and 'Modem'. Your phone needs to be set to modem in order to serve as a modem, you can use mass storage mode if you just want to sync up your files (pictures, music, etc) with your pc. You'll also want to make sure that your provider has the internet setup for you to use your phone as a modem.
and if you have already installed in prior to reading this, you will need to uninstall the program and begin again with the steps above. I hope this helps.
--MsFixit923
Posted on Feb 14, 2009
My problem is the same, I am on vista, I downloaded the latest software, it charges the battery when connected, but says the phone is not connected. version 3.2.2.HG5
Regards
Posted on Nov 03, 2008
Install the PC software, then the USB driver. Have to be patient with Vista had to load several times. Also, make sure phone is not connected when you do this.
Posted on Dec 21, 2008
When insalling my phone to my laptop which is a samsung diva it says no nps exists..what i it? how do i solve the problem?
This is a fairly common problem with samsung media studio and 64 bit versions of windows. If you have a 64 bit version of windows, try running your samsung media studio in 32 bit mode.
Other people have found that re-installing the samsing PC studio can be helpful, and further people have done this to counteract the entire ordeal:
1. choose to save files to memory card, not phone.
2. make sure files are saved to memory card on phone, not internal memory.
3. select mass storage mode on phone
4. connect with usb cable
5. pc recognises memory card on phone as external drive, so you can access files.
May 03, 2011 | Cell Phones
When I connect my samsung monte c3200 phone with pc through cable it says USB device not recognised. I set it to seting > pc connection > ask on connection. Blue tooth is off. Already...
Plug your usb cable into your computer available usb port.Check for the hardware specification, like usb 1.0, usb 1.1. or usb 2.0. Try also installing your device and kies applicatin to other computer to identify or to troubleshoot where exactly the problem. Good day
Nov 30, 2010 | Samsung USB Interface Data Cable for...
Samsung E2210L Connecting to PC wont recognise
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make
Apr 10, 2010 | Cell Phones
My samsung phone is not connecting through data cable with my pc. i bought a new samsung set of beat addition 2 days before for using internet through data cable. but my phone is not connecting with my pc...
run again your pc studio cd software installer..
by default, it will play and give the swf home page where there is an option for install usb driver. select install usb driver in order to install your usb driver but before installation disconnect your phone from pc and remove the usb cable. once it's installed, right click your PC studio and select open automatically when device is connected.
>>on your phone, select settings,select settings for your pc connections, check ask for connections and reconnect your phone.
Feb 21, 2010 | Samsung Beat SGH-T539 Cellular Phone
Can't connect SAMSUNG MOBILE SGH-U900 to my PC
it may be in a qualcom usb mode... try this code. *#726872#.. it will says Samsung usb..... etc plz connect cable..
connect ur data cable and start ur pc studio, it will work..
Aug 21, 2009 | Samsung U900 Soul Cellular Phone
Usb not recognized
you can try this. install pc studio, and then connect your mobile...it should automatically install the drivers..but if that is what you have done then you can try updating the PC studio software.
Nov 29, 2008 | Samsung SGH-D900 Cellular Phone
My samsung G600 wont connect to my pc studio 3 on computer?
If you are using pc studio you must first check that it is set to use it.Try this first:-
1,settings-phones settings-USB settings-pc studio.
2,If not then check that your pc USB's are switched on.
Aug 25, 2008 | Samsung SGH-G600 Cellular Phone
My new Samsung E900 isn't being recognised by PC Studio 3.
My son's phone did the same. I went into the windows control panel, performance and maintenance, system. Selected hardware, device manager, and refreshed the drivers from there.That cleared the problem.
Nov 28, 2007 | Samsung SGH-D900 Cellular Phone
Samsung u600 mobile phone
run a live update for pc studio 3. Should fix the problem.
If not, check whether when you connect the usb cable to the phone, the option selected is "PC Studio" in the phone
Samsung J750 Triband Black Unlocked 3G Phone Logo
1,690 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
