Question about Technics SA-AX720 Receiver
Technics SA-AX720 AMP
WHEN I TURN IT ON IT JUST SATS OVERLOAD IF I PRESS ANYTHING IT SAYS SWITCH OFF POWER
  • soucy1 Jan 29, 2009
    Is this easy to replace ? And could I do it myself?
    Genius:
  • Technics Master
  • 1,550 Answers
The audio amplifier IC of your device are damaged you need to replace it.
Posted on Jul 04, 2008
Can i hook a amplifier to my technics receiver model no sa-ax720
If the Amplifier has more Output Power and Better Quality Sound then it is worthwhile to do so -Yes you can connect Amp to Technics Receiver you have mentioned
Jun 24, 2015 | Technics Audio Players & Recorders
My receiver technics sa-ax720 keeps making a clicking noise and then it will say on the screen "overload" and then shut off.
try checking for broken solder connections on the amp ic's and regulators. That is a pretty common problem with these
Jul 27, 2014 | Audio Players & Recorders
Trying to hook up SH-AC500D to SA-AX720 Receiver. I wanna know the right wires to use. Thank you
Connect the 6-channel analog outputs of the AC500 to the 6-channel analog inputs on the AX720 using 3 RCA cable pairs.
http://archiwumallegro.pl/technics_shac500d_procesor_surround_ddigital_dts-1215399983.html
Digital sources will enter the AC500 and be converted to 5.1 analog output.
Be advised, that input on the receiver will not allow any internal DSP manipulation. WYSIWYG.
Feb 04, 2011 | Technics SA-AX720 Receiver
My Technics SA-GX100 Reciever worked for a minute, but when i set it up with all the speakers and attachments, it says "muting". i dont have a remote, so how do i UNMUTE it?
According to my Technics SA-R210 manual to UNMUTE without the remote....do the following......PRESS BOTH THE VOL UP & DOWN CONTROLS & THE LOUDNESS SWITCH ON THE UNIT AT THE SAME TIME......Not sure it will work for your model but that is what it shows for The Technics SA-R210 model, so it should be pretty much the same
Sep 04, 2010 | Technics SA-AX720 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Same problem
The overload indication tells us that there is a problem in the final stage of the amplifier section. This model uses an AMP-PAC or large amplifier IC (part number RSN-3305) which is now defective. If you can solder, try resoldering the pins on this IC. Sometimes a poor solder connection can cause a voltage offset that will be detected as a fault and shutdown the system like this. If the resoldering fails, the IC will need to be replaced. Parts cost will be in the $75-$95 range.
Dan
Sep 14, 2009 | Technics SA-AX720 Receiver
Looking for user manual for Technics SA-AX720 receiver
You can download them, depending where you are, I have one!
Jun 07, 2009 | Technics SA-AX720 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
510 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
