The hong kong n76 accepts both english and simplified chinese input so it is posible that you can change the language if you can find it although if your phone has as i suspect been flashed with the chinese version firmware then you may need to have the phone reflashed with the english version. You can get a nokia service point to do this for a small charge or if you feel confident can do it yourself with something like, nemesis software and the usb cable that came with it.
I cannot access the web on my N76,How can I access it again?I use to access it but after several...
(More)
I cannot access the web on my N76,How can I access it again?I use to access it but after several times of using it all I have is an error message packet data not available.How do I fix this?
press call+*+3 this trick not working any other trick n76 Phone start-up failed. contact the...
(More)
press call+*+3 this trick not working any other trick n76 Phone start-up failed. contact the retailer
After a little digging around on the net, I managed to get back into the handset by doing pressing...
(More)
After a little digging around on the net, I managed to get back into the handset by doing pressing yes+*+3 while powering on the handset n76
