Dvd drive wont open - Computers & Internet
  • themightyoak Jan 18, 2009
    Is there any way o fix it totally so you can use the button? Does the computer have to be off to use the hole thingy with a paper clip? Would getting a new dvd drive fix the problem?
  • 100 Answers
Its a common problem. There is a very tiny hole on the dvd-rom, try to find it.
Then get something that would get into that hole, and push that something into the hole and apply pressure, it should open.
Also slamming the dvd-drive after clicking the open button would work, I do that myself, but it would totally break after time, so just use the hole thingy :)
cheers.
Posted on Jul 04, 2008
Hp pavillion wont eject dvd
Turn system off and use a paper clip to manually open the drive door. Straighten a paper clip, then insert it in the small opening to the right of the eject button. This should manually open the door and you can remove any disks in the drive. Then reboot and see if it will open and close normally.
Jan 16, 2014 | Dell (0F146) Internal DVD Drive
DVD Wont Eject properly
Sound like you might have a bad DVD drive the only recourse might be just replace the DVD drive. If it won't open.. most often you can use a paper clip to open the drive. There is usually a small hole near the eject button on the DVD drive where you can insert a paper clip end to open the drive and pull out the DVD. After removing the DVD you can test if the drive eject or not correctly with nothing in it. If it doesn't, have the drive replaced.
Nov 06, 2013 | Acer Computers & Internet
Dvd player
The drive mechanism could be binding or the drive motor may have become too weak to open or close the disk tray
Jun 23, 2013 | Televison & Video
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
The dvd player wont open and it isn't reading dvd's.
You will want to check in Device Manager to see if the device is even detected by the computer. Right Click My Computer, Properties, Click Hardware Tab and Device Manager. If it isn't recognizing the DVD drive then it is most likely bad.
Nov 30, 2011 | HP Compaq Presario SR5010 Desktop PC...
My dvd burner wont open
on the drive there should be a small hole open up a paperclip and insert it this fill push against the cd frame and open the tray
Nov 06, 2011 | Computers & Internet
Actually my dvd is not opening when i m pressing the open/close button.
It could be a "physical" problem.
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the face-plate of the drive,
and push until you feel resistance.
Then, firmly push another 10mm (1/4 inch) and the drive should "unlock" and open slightly.
Press the open/close button to fully open the tray.
Dec 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Drive door stuck and wont open
You can always try getting a jumbo paperclip, unbending it once, and inserting it into the small circular hole on the front of your drive. If your drive doesn't have the hole, then you'll have to probably take it to a repair shop.
Good Luck!
Jan 23, 2010 | Sony (DRU720A) DVD±RW Dual Layer...
Wont work
right click on dvd drive on my computer then eject the dvd drive,,,,,,,after that
open bios setting and check device configuration
Jul 02, 2009 | Dell Inspiron 1501 PC Notebook
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
