Ports cant open ports in bthomehub router, can anyone help?
    Scholar:
  • 174 Answers
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 06, 2011 | Arris SURFboard SBG900 Wireless Router...
I have an actiontec router and cant set my nat type to open. If i turn off nat i cant get on xbox live. It says in the actiontec website for my router that i have to do something with port forwarding to...
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
Aug 09, 2010 | Actiontec (GT701WG) Wireless Router
I cant open my ports on my computer and im getting fustrated!!
if your running through a router then the address is normally something like http://192.168.0.1 if that's not it yours will be on your router no log in and find port forwarding and open the ports you need open hope this has helped
May 19, 2010 | Computers & Internet
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Jan 09, 2010 | Cnet CWR-854 Router
I'm trying to set up a wireless network for the first time... can anyone walk me through it??
connect the Modem to the WAN or Internet port of the router then wired the computer to any LAN port of the router.
Open IE and type the IP address of the router
Login to the router
Example if its Dlink
IP is 192.168.0.1
user: admin
pass: none
If linksys: 192.168.1.1
user: none
pass: admin
Then run the setup wizard!
if you cant find the password click here:
www.routerpasswords.com
Apr 28, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Router cant handle two pc's connecting to same server
Try to do port forwarding. Search for the port number that the game uses and open it on the router's Setup Page using Port Forwarding.
Apr 25, 2009 | Linksys (WRT54GC) Router
Xbox 360 not connecting to online parties or games
If there is a firewall or a router between the Xbox console and the networking hardware, and the Xbox LIVE test reports a NAT problem, you may have to make configuration changes to enable communication on the specific network ports that are required by Xbox LIVE. This will not guarantee that this will give you an "open" NAT status, but it may help.
If you are using an Xbox LIVE-compatible or Windows Vista-compatible device with the correct firmware installed, you do not have to manually open any ports. For a device to gain "compatible" status, the device and the firmware must perform specific functions with Xbox LIVE. These functions include (but are not limited to) setting NAT to "Open" and having the ability to connect multiple consoles to a single router. For more information about how to find out if your networking hardware is compatible with Xbox LIVE, click the following article number to view the article in the Microsoft Knowledge Base: 944293 (http://support.microsoft.com/kb/944293/ ) How to find out if your networking hardware is compatible with the Xbox LIVE Service If your device is not on the compatible list, you can try opening the following ports:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
For information about how to configure port settings on a firewall, a router, or a gateway, please see the documentation that was included with that device or contact your network administrator or local technical support for help. You can also check the xbox.com official forums to see if other users have the same problem.
If you use a Windows Vista-certified or Xbox LIVE-certified device and the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," verify that the device has the current firmware. For information about Xbox LIVE-certified devices, such as the correct firmware version for the device, please visit the following Xbox Web site: http://winqual.microsoft.com/HCL/ProductList.aspx?m=v&cid=712&g=d
Mar 25, 2009 | Microsoft Xbox 360 Console
Sony psp
see yur psp guide 1st....may be you need to open or configure the network connection...
Mar 14, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How to reconfigure router
you may need to reset to restore the defaults.
the the default username: admin and password: admin
Jan 16, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Computers & Internet Logo
David Payne
David Payne
