Hotpoint wd62p or aquarius washer dryer .fault no drum rotation .moter seems ok carbon brushes ok .belt ok machine takes in water wants to advance .have motor out to check measures 5ohms rotting all round. my names fred please email paaudiovideo@btconnect.com and or wfwalmsley@aol.com many thanks.
    Genius:
  • 1,036 Answers
Hi Fred,
If the motor buzzes, makes little movements but does not have the power to spin, then you need to replace the run capacitor for the motor. It's a big cylindrical one you can't miss.
No real test for them, just replace.
This is usually the fault - worn brushes, stuck brushes or duff capacitor.
(Mine's on it's way out too on an aquarius WD61, but like the plumbers tap - I'll wait a bit before doing it lol! )
Posted on Jul 04, 2008
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Have WD63 WASHER/DRYER & the drum stopped turning. motor ok & drum turns easily when turned manually.
Could be the carbon brushes on the motor. They're usually quite cheap and easy to replace. In this area you can expect to see a lot of carbon dust (black). The brushes themselves should protrude from the case by around 4-6mm.
Could also be a loose connection between the power feed and the motor.
Will it pump? Some machines die completely when the pump fails.
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Jun 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Aquarus 1200 hotpoint motor not working
Check the motor brushes for wear.
Replacement carbon mototr brushes available at :
www.hotpointspares2u.co.uk
Regards
Steve - SDA Ltd
Aug 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd640 replacement motor brushes
machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Jun 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
Hello
If you look at the motor which of course is on the top right of the drum. you will see either white or black palstic parts inserted eiterh side and a wire connected to them
These are the brush holders for the carbon brushes.. These have worn out and need replacing easily done just get yourselfthe parts and remove the old one and replace with the new ones....
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1100
yes easy to change there are 2 of them look for a single wire going to each side of your motor when u find each wire u have found were your carbon brushes are right you will need a pair of bent nose pliers place the ends either side of the plastic casing if the carbon brushes squeeze and pull the first brush should pull out take wire of now the 2 brush you wont be able to see but its directly across from the first 1 do exact same to take that 1 out now before replacing the new brushes there a small slot running down 1 side of the plastic at the end you will see a small metal bar push this up which will release the carbon now you can fit them
Dec 11, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
