Question about IBM ThinkPad T23 2647 Notebook
Battery Type 2647 The oragnge battery light keeps flashing and the lap top only works on mains power. Does this mean that the battery is finished and needs replacing or is there anything else I can do? thanks
    Scholar:
  • 94 Answers
Generally yes! That battery may be toast.
One or more cells in the battery cannot take a charge or is shorted..
Posted on Jul 04, 2008
Caps lock light flashing and laptop not responding
Hello.
Disconnect all power. Flip the laptop to unlock and remove the battery. Reinsert and lock the battery. Power on, again.
Hope this helps.
Jan 05, 2012 | Dell Keyboard for Inspiron 1300 B120 B130...
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
There is a flashing red light with a line between on canon ZR40 what does this mean
That is the symbol for the backup battery. It's a button-type battery that keeps enough power to remember the date and time when the main battery is removed. If the icon is lit, it means this battery should be replaced. Check your manual for location and type of battery. If you need, you can view and download the manual here.
Feb 18, 2010 | Canon ZR40 Mini DV Digital Camcorder
Lap top not charging . purple light is not on. is it battery or charger?
the charger lasts longer than the battery .you need another lap top battery
Oct 16, 2009 | Computers & Internet
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Laptop Not booting - No Screen
Clean your memory card, or reseat it. Clean the edge connector with soft eraser if reseating doesn't solve it. Do this when battery is disconnected, completely turn off and no other power supply is connected to it. If not maybe ram failed already. This is the first step before going to anything. For additional instructions try to find it in youtube. Post us some update.tnx
Jun 06, 2009 | IBM ThinkPad T20 2647 Notebook
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
MY ACER ASPIRE 1640 LAP TOP WILL NOT STAR UP. WHEN TURNING ON THE POWER BUTTON FLASHES ON AND OFF. WHEN PLUGGED INTO THJE MAINS THE CHARGING LIGHT SHOWS YELLOW BUT THE COMPUTER WILL NOT TURN ON
check the power supply to the mains where the lap top is plugged and comfirm if there is power supply and for any possible drop in power output which may affect the charging
Aug 04, 2008 | Acer Computers & Internet
The 4 bars on the front of my lap top the third bar in keeps flashing red. does that mean I need a new battery even if it is on the outlet.
Sometimes it happens battery charging, If you can off the outlet and your lap top automatically off thats the time you will change your battery.
Jun 11, 2008 | Computers & Internet
IBM ThinkPad T23 2647 Notebook Logo
83 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
